Datasheet ADIS16448 (Analog Devices) - 9
DescriptionCompact, Precision Ten Degree of Freedom Inertial Sensor
Pages / Page26 / 9 — ADIS16448. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP …
RevisionH
File Format / SizePDF / 619 Kb
ADIS16448. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP VIEW. (Not to Scale). IO2. IO1. IO3. DNC. PIN 1. IO4. PIN 20
ADIS16448 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TOP VIEW (Not to Scale) IO2 IO1 IO3 DNC PIN 1 IO4 PIN 20
ADIS16448 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ADIS16448 TOP VIEW (Not to Scale) K ND ND DD IO2 N IO1 CL IO3 DNC DNC G G V D D DI S D 19 17 15 13 11 9 7 5 3 1 20 18 16 14 12 10 8 6 4 2 PIN 1 T IN ND DD DD CS UT DNC DNC DNC G V V RS LK DO /C IO4 PIN 20 D NOTES 1. THIS REPRESENTATION DISPLAYS THE TOP VIEW WHEN THE USE THIS OPENING FOR CONNECTOR IS VISIBLE AND FACING UP. REMOTE PRESSURE SENSING.
005 106
2. MATING CONNECTOR: SAMTEC CLM-110-02 OR EQUIVALENT. HOLE IS TAPPED 3. DNC = DO NOT CONNECT.
09946-
FOR 10-32 SCREW THREADS.
09946- Figure 5. Pin Configuration Figure 6. Pin Locations
Table 5. Pin Function Descriptions Pin No. Mnemonic Type1 Description
1 DIO3 I/O Configurable Digital Input/Output. 2 DIO4/CLKIN I/O Configurable Digital Input/Output or Sync Clock Input. 3 SCLK I SPI Serial Clock. 4 DOUT O SPI Data Output. Clocks the output on the SCLK falling edge. 5 DIN I SPI Data Input. Clocks the input on the SCLK rising edge. 6 CS I SPI Chip Select. 7 DIO1 I/O Configurable Digital Input/Output. 8 RST I Reset. 9 DIO2 I/O Configurable Digital Input/Output. 10, 11, 12 VDD S Power Supply. 13, 14, 15 GND S Power Ground. 16, 17, 18, 19, 20 DNC N/A Do Not Connect. Do not connect to these pins. 1 I is input, O is output, S is supply, and N/A is not applicable. Rev. F | Page 8 of 25 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS USER REGISTERS USER INTERFACE READING SENSOR DATA Burst Read Function Burst Read Function with CRC SPI Read Test Sequence DEVICE CONFIGURATION Dual Memory Structure OUTPUT DATA REGISTERS GYROSCOPES ACCELEROMETERS MAGNETOMETERS BAROMETRIC PRESSURE REMOTE PRESSURE SENSING INTERNAL TEMPERATURE SYSTEM FUNCTIONS GLOBAL COMMANDS PRODUCT IDENTIFICATION SELF-TEST FUNCTION STATUS/ERROR FLAGS Magnetometer/Barometer New Data Indicator MEMORY MANAGEMENT Checksum Test INPUT/OUTPUT CONFIGURATION DATA READY INDICATOR GENERAL-PURPOSE INPUT/OUTPUT Example Input/Output Configuration DIGITAL PROCESSING CONFIGURATION GYROSCOPES/ACCELEROMETERS INPUT CLOCK CONFIGURATION Digital Filtering Dynamic Range MAGNETOMETER/BAROMETER New Data Indicators CALIBRATION GYROSCOPES Gyroscope Bias Error Estimation Gyroscope Bias Correction Factors Single Command Bias Correction ACCELEROMETERS Accelerometer Bias Error Estimation Accelerometer Bias Correction Factors Point of Percussion Alignment MAGNETOMETER CALIBRATION Hard Iron Correction Hard Iron Factors Soft Iron Effects FLASH UPDATES RESTORING FACTORY CALIBRATION ALARMS STATIC ALARM USE DYNAMIC ALARM USE ALARM REPORTING Alarm Example APPLICATIONS INFORMATION MOUNTING TIPS POWER SUPPLY CONSIDERATIONS ADIS16IMU2/PCBZ PC-BASED EVALUATION TOOLS OUTLINE DIMENSIONS ORDERING GUIDE
