link to page 8 Data SheetADIS16362PIN CONFIGURATION AND FUNCTION DESCRIPTIONSADIS16362TOP VIEW(Not to Scale)K_ADCIO3CLNIO1IO2CCNDNDDSDIDDVGGDNCDNCAUXDNC135791113151719212324681012141618202224INTUTCSCCCCNDLKRSVVGDNCDNCDNCDNCDO_DAC/CIO4AUXDNOTES 1. THIS REPRESENTATION DISPLAYS THE TOP VIEW PINOUTFOR THE MATING SOCKET CONNECTOR.2. THE ACTUAL CONNECTOR PINS ARE NOT VISIBLE FROM THE TOP VIEW. 3. MATING CONNECTOR: SAMTEC CLM-112-02 OR EQUIVALENT. 005 4. DNC = DO NOT CONNECT. 08179- Figure 5. Pin Configuration Z-AXISaZgZY-AXISX-AXISaYaXgYgXPIN 23ORIGIN ALIGNMENT REFERENCE POINTPIN 1SEE MSC_CTRL[6].NOTES 1. ACCELERATION (aX, aY, aZ) AND ROTATIONAL (gX, gY, gZ) ARROWS INDICATE THE DIRECTION OF MOTION THAT PRODUCES 006 A POSITIVE OUTPUT. 08179- Figure 6. Axial Orientation Table 5. Pin Function Descriptions Pin No.MnemonicType1Description 1 DIO3 I/O Configurable Digital Input/Output. 2 DIO4/CLKIN I/O Configurable Digital Input/Output or Sync Clock Input. 3 SCLK I SPI Serial Clock. 4 DOUT O SPI Data Output. Clocks output on SCLK falling edge. 5 DIN I SPI Data Input. Clocks input on SCLK rising edge. 6 CS I SPI Chip Select. 7, 9 DIO1, DIO2 I/O Configurable Digital Input/Output. 8 RST I Reset. 10, 11, 12 VCC S Power Supply. 13, 14, 15 GND S Power Ground. 16, 17, 18, 19, 22, 23, 24 DNC N/A Do Not Connect. 20 AUX_DAC O Auxiliary, 12-Bit DAC Output. 21 AUX_ADC I Auxiliary, 12-Bit ADC Input. 1 I/O is input/output, I is input, O is output, S is supply, N/A is not applicable. Rev. E | Page 7 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Operation Reading Sensor Data Device Configuration Memory Map Burst Read Data Collection Output Data Registers Calibration Manual Bias Calibration Gyroscope Automatic Bias Null Calibration Gyroscope Precision Automatic Bias Null Calibration Restoring Factory Calibration Linear Acceleration Bias Compensation (Gyroscope) Operational Control Global Commands Internal Sample Rate Power Management Sensor Bandwidth Digital Filtering Dynamic Range Input/Output Functions General-Purpose I/O Input Clock Configuration Data Ready I/O Indicator Auxiliary DAC Diagnostics Self-Test Memory Test Status Alarm Registers Product Identification Applications Information Installation/Handling Gyroscope Bias Optimization Input ADC Channel Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
