link to page 6 link to page 6 link to page 6 Data SheetADIS16364TIMING SPECIFICATIONS TA = 25°C, VCC = 5 V, unless otherwise noted. Table 2.Normal ModeLow Power Mode(SMPL_PRD ≤ 0x09)(SMPL_PRD ≥ 0x0A)Burst ReadParameter DescriptionMin1TypMaxMin 1 TypMaxMin 1 TypMaxUnit f Serial clock 0.01 2.0 0.01 0.3 0.01 1.0 MHz SCLK t Stall period between data 9 75 1/f µs STALL SCLK t Read rate 40 100 µs READRATE t Chip select to SCLK edge 48.8 48.8 48.8 ns CS t DOUT valid after SCLK edge 100 100 100 ns DAV t DIN setup time before SCLK rising edge 24.4 24.4 24.4 ns DSU t DIN hold time after SCLK rising edge 48.8 48.8 48.8 ns DHD t , t SCLK rise/fall times 5 12.5 5 12.5 5 12.5 ns SCLKR SCLKF t , t DOUT rise/fall times 5 12.5 5 12.5 5 12.5 ns DR DF t SFS CS high after SCLK edge 5 5 5 ns t Input sync positive pulse width 5 5 µs 1 t Input sync low time 100 100 µs x t Input sync to data ready output 600 600 µs 2 t Input sync period 833 833 µs 3 1 Guaranteed by design and characterization, but not tested in production. TIMING DIAGRAMSCStCStSFS1234561516SCLKtDAVDOUTMSBDB14DB13DB12DB11DB10DB2DB1LSBttDSUDHDDINR/WA6A5A4A3A2D2D1LSB 002 07906- Figure 2. SPI Timing and Sequence tREADRATEtSTALLCSSCLK 003 07906- Figure 3. Stall Time and Data Rate t3t2tt1XSYNCCLOCK (DIO4) 004 DATAREADY 07906- Figure 4. Input Clock Timing Diagram Rev. E | Page 5 of 20 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Operation Reading Sensor Data Device Configuration Memory Map Burst Read Data Collection Output Data Registers Calibration Manual Bias Calibration Gyroscope Automatic Bias Null Calibration Gyroscope Precision Automatic Bias Null Calibration Restoring Factory Calibration Linear Acceleration Bias Compensation (Gyroscope) Operational Control Global Commands Internal Sample Rate Power Management Sensor Bandwidth Digital Filtering Dynamic Range Input/Output Functions General-Purpose I/O Input Clock Configuration Data Ready I/O Indicator Auxiliary DAC Diagnostics Self-Test Memory Test Status Alarm Registers Product Identification Applications Information Installation/Handling Gyroscope Bias Optimization Input ADC Channel Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
