Datasheet ADXRS290 (Analog Devices) - 7
DescriptionUltralow noise, dual-axis MEMS Gyroscope for Stabilization Applications
Pages / Page20 / 7 — ADXRS290. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. TION. T OF P. …
RevisionA
File Format / SizePDF / 578 Kb
ADXRS290. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. TION. T OF P. –500 –400 –300 –200 –100. 100. 200. 300. 400. 500
ADXRS290 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS TION T OF P –500 –400 –300 –200 –100 100 200 300 400 500
N > 240 for all typical performance characteristics plots, unless otherwise noted.
70 40 60 35 ) ) % % ( ( 30 50 TION TION 25 LA LA U 40 U OP OP 20 30 T OF P T OF P 15 N N E E C 20 C R R 10 E E P P 10 5 0 0 –500 –400 –300 –200 –100 0 100 200 300 400 500
004
007
X-AXIS OFFSET (LSB)
12636-
Y-AXIS OFFSET (LSB)
12636- Figure 4. X-Axis Offset at 25°C Figure 7. Y-Axis Offset at 25°C
400 1500 300 1000 200 ) 500 ) B 100 B LS LS T ( 0 T ( E 0 E OFFS –100 OFFS –500 –200 –1000 –300 –400 –1500 –50 –25 0 25 50 75 100
005
008
TEMPERATURE (°C)
12636-
TEMPERATURE (°C)
12636- Figure 5. X-Axis Offset vs. Temperature (N = 16) Figure 8. Y-Axis Offset vs. Temperature (N = 16)
22 20 20 18 ) 18 ) % 16 % ( ( 16 14 TION 14 TION LA LA 12 U U 12 OP OP 10 10 8 T OF P 8 T OF P N N E E C 6 6 C R R E E P 4 P 4 2 2 0 0
006 009
180 182 184 186 188 190 192 194 196 198 200 202 204 206 208 210 212 214 216 218 220 180 182 184 186 188 190 192 194 196 198 200 202 204 206 208 210 212 214 216 218 220 X-AXIS SENSITIVITY (LSB/°/s)
12636-
Y-AXIS SENSITIVITY (LSB/°/s)
12636- Figure 6. X-Axis Sensitivity at 25°C Figure 9. Y-Axis Sensitivity at 25°C Rev. A | Page 6 of 19 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXES PACKAGE INFORMATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION APPLICATION CIRCUIT POWER SUPPLY DECOUPLING POWER SEQUENCING SETTING BANDWIDTH Offset Preservation in the High-Pass Filter ANALOG EVALUATION MODE MECHANICAL CONSIDERATIONS FOR MOUNTING SERIAL COMMUNICATIONS REGISTER MAP REGISTER DESCRIPTIONS ANALOG DEVICES IDENTIFIER MEMS IDENTIFIER DEVICE IDENTIFIER SILICON REVISION NUMBER SERIAL NUMBER (SNx) RATE OUTPUT DATA Register 0x08 to Register 0x0B: DATAX0, DATAX1, DATAY0, and DATAY1 (Read Only) TEMPERATURE DATA Register 0x0C to Register 0x0D: TEMP0 and TEMP1 (Read Only) POWER CONTROL TSM Bit Measurement Bit BAND-PASS FILTER LPF Bits HPF Bits DATA READY Sync Bits RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN OUTLINE DIMENSIONS ORDERING GUIDE
