Datasheet ADXRS290 (Analog Devices) - 10
DescriptionUltralow noise, dual-axis MEMS Gyroscope for Stabilization Applications
Pages / Page20 / 10 — Data Sheet. ADXRS290. % (. TION LA. T OF P N E. C R E P. 6.5. 6.6. 6.7. …
RevisionA
File Format / SizePDF / 578 Kb
Data Sheet. ADXRS290. % (. TION LA. T OF P N E. C R E P. 6.5. 6.6. 6.7. 6.8. 6.9. 7.0. 7.1. 7.2. 7.3. 7.4. 7.5. MEASUREMENT MODE CURRENT (mA)
Data Sheet ADXRS290 % ( TION LA T OF P N E C R E P 6.5 6.6 6.7 6.8 6.9 7.0 7.1 7.2 7.3 7.4 7.5 MEASUREMENT MODE CURRENT (mA)
Data Sheet ADXRS290 50 45 ) 40 % ( 35 TION LA 30 U OP 25 20 T OF P N E 15 C R E P 10 5 0
024
12636- Figure 22. Measurement Mode Current Consumption Rev. A | Page 9 of 19 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXES PACKAGE INFORMATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION APPLICATION CIRCUIT POWER SUPPLY DECOUPLING POWER SEQUENCING SETTING BANDWIDTH Offset Preservation in the High-Pass Filter ANALOG EVALUATION MODE MECHANICAL CONSIDERATIONS FOR MOUNTING SERIAL COMMUNICATIONS REGISTER MAP REGISTER DESCRIPTIONS ANALOG DEVICES IDENTIFIER MEMS IDENTIFIER DEVICE IDENTIFIER SILICON REVISION NUMBER SERIAL NUMBER (SNx) RATE OUTPUT DATA Register 0x08 to Register 0x0B: DATAX0, DATAX1, DATAY0, and DATAY1 (Read Only) TEMPERATURE DATA Register 0x0C to Register 0x0D: TEMP0 and TEMP1 (Read Only) POWER CONTROL TSM Bit Measurement Bit BAND-PASS FILTER LPF Bits HPF Bits DATA READY Sync Bits RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN OUTLINE DIMENSIONS ORDERING GUIDE
