Datasheet ADXRS290 (Analog Devices) - 3
DescriptionUltralow noise, dual-axis MEMS Gyroscope for Stabilization Applications
Pages / Page20 / 3 — ADXRS290. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 12/14—Rev.0 to …
File Format / SizePDF / 578 Kb
ADXRS290. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 12/14—Rev.0 to Rev. A. 10/14—Revision 0: Initial Version
ADXRS290 Data Sheet TABLE OF CONTENTS REVISION HISTORY 12/14—Rev.0 to Rev A 10/14—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 3 link to page 5 link to page 5 link to page 5 link to page 5 link to page 6 link to page 7 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 14 link to page 15 link to page 17 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 19 link to page 19 link to page 20 link to page 20
Features .. 1 Mechanical Considerations for Mounting .. 13 Applications ... 1 Serial Communications ... 14 General Description ... 1 Register Map ... 16 Functional Block Diagram .. 1 Register Descriptions ... 17 Revision History ... 2 Analog Devices Identifier .. 17 Specifications ... 3 MEMS Identifier ... 17 Absolute Maximum Ratings .. 4 Device Identifier ... 17 Rate Sensitive Axes ... 4 Silicon Revision Number .. 17 Package Information .. 4 Serial Number (SNx) ... 17 ESD Caution .. 4 Rate Output Data ... 17 Pin Configuration and Function Descriptions ... 5 Temperature Data ... 17 Typical Performance Characteristics ... 6 Power Control ... 17 Theory of Operation .. 10 Band-Pass Filter .. 17 Applications Information .. 11 Data Ready .. 17 Application Circuit ... 11 Recommended Soldering Profile ... 18 Power Supply Decoupling ... 11 PCB Footprint Pattern ... 18 Power Sequencing .. 11 Outline Dimensions ... 19 Setting Bandwidth .. 11 Ordering Guide .. 19 Analog Evaluation Mode ... 12
Changes to Title .. 1 Changes to Features Section and General Description Section ... 1
Rev. A | Page 2 of 19 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXES PACKAGE INFORMATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION APPLICATION CIRCUIT POWER SUPPLY DECOUPLING POWER SEQUENCING SETTING BANDWIDTH Offset Preservation in the High-Pass Filter ANALOG EVALUATION MODE MECHANICAL CONSIDERATIONS FOR MOUNTING SERIAL COMMUNICATIONS REGISTER MAP REGISTER DESCRIPTIONS ANALOG DEVICES IDENTIFIER MEMS IDENTIFIER DEVICE IDENTIFIER SILICON REVISION NUMBER SERIAL NUMBER (SNx) RATE OUTPUT DATA Register 0x08 to Register 0x0B: DATAX0, DATAX1, DATAY0, and DATAY1 (Read Only) TEMPERATURE DATA Register 0x0C to Register 0x0D: TEMP0 and TEMP1 (Read Only) POWER CONTROL TSM Bit Measurement Bit BAND-PASS FILTER LPF Bits HPF Bits DATA READY Sync Bits RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN OUTLINE DIMENSIONS ORDERING GUIDE
