Datasheet ADXRS645 (Analog Devices) - 2
DescriptionHigh Temperature, Vibration Rejecting ±2000°/sec Gyroscope
Pages / Page11 / 2 — ADXRS645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 362 Kb
ADXRS645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXRS645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADXRS645 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXRS645 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADXRS645 EngineerZone Discussions. • ADXRS645: High Temperature, Vibration Rejecting ±2000°/sec Gyroscope Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-831: Evaluating the ADXRS645 High Temperature, Vibration Rejecting ±2000°/sec Gyroscope
TECHNICAL SUPPORT
Submit a technical question or find your regional support
REFERENCE MATERIALS
number.
Press
• Analog Devices Introduces Industry’s Fastest, Most
DOCUMENT FEEDBACK
Accurate and Lowest Power High-Temperature SAR A/D Submit feedback for this data sheet. Converter • Industry’s First High-Temperature MEMS Gyroscope Improves Productivity of Oil and Gas Drilling Equipment
Technical Articles
• MS-2707: Harsh Environments Conquered - Low Power, Precision, High Temperature Components for Extreme High Temperature Applications • Precision Inertial Sensing in Harsh, High Temperature Environments
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Supply Ratiometricity Range Extension Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
