Datasheet ADXRS645 (Analog Devices) - 9
DescriptionHigh Temperature, Vibration Rejecting ±2000°/sec Gyroscope
Pages / Page11 / 9 — ADXRS645. Data Sheet. –30. TION. –60. LA U. SE (d. rees). –90. Deg (. OF …
RevisionA
File Format / SizePDF / 362 Kb
ADXRS645. Data Sheet. –30. TION. –60. LA U. SE (d. rees). –90. Deg (. OF P. ESPO. E R T. HAS. –12. –120. C R E P. –15. –150. –18. –180. 0.1. 3150. 3250. 3350. 3450. 3550
ADXRS645 Data Sheet –30 TION –60 LA U SE (d rees) –90 Deg ( OF P ESPO E R T HAS –12 –120 C R E P –15 –150 –18 –180 0.1 3150 3250 3350 3450 3550
ADXRS645 Data Sheet 35 0 0 ) 30 % –3 –30 ( ) 25 TION B –6 –60 LA U SE (d 20 rees) OP N –9 –90 Deg ( OF P ESPO E 15 GE E R T HAS TA –12 –120 A P N 10 E R C R E P –15 –150 5 0 –18 –180 0.1 1 10
018 16
3150 3250 3350 3450 3550 3650 3750 3850 3950 4050 4150
1
FREQUENCY (kHz)
1958- 1
CURRENT CONSUMPTION (mA)
1958- 1 Figure 17. Current Consumption at 25°C (VRATIO = 5 V) Figure 19. Typical Rate and Phase Response vs. Frequency (COUT = 470 pF with a Series RC Low-Pass Filter of 3.3 kΩ and 22 nF)
1 0.04 z) 0.03 H 0.02 ec/√ (°/s S) 0.01 0.1 F SITY (% 0 Y EN T L D 0.01 ARI A TR INE 0.02 NL 0.01 PEC NO 0.03 E S 0.04 OIS N 0.05 0.001 0.06
17
0.1 1 10 100 1k 10k
1
–2000 –1000 0 1000 2000
019
FREQUENCY (Hz)
1958- 1
RATE (°/sec)
1958- 1 Figure 18. Typical Noise Spectral Density (COUT = 0.01 µF) Figure 20. Typical Output Nonlinearity Rev. A | Page 8 of 10 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Supply Ratiometricity Range Extension Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
