Datasheet ADIS16137 (Analog Devices) - 2
Description±1000°/Sec Precision Angular Rate Sensor
Pages / Page21 / 2 — ADIS16137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 521 Kb
ADIS16137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16137 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • Breakout Board for the ADIS1613x, ADIS1637x, ADIS1648x • Symbols and Footprints and ADIS1649x • EVAL-ADIS Evaluation System
DISCUSSIONS
View all ADIS16137 EngineerZone Discussions.
DOCUMENTATION Data Sheet SAMPLE AND BUY
• ADIS16137: ±1000°/Sec Precision Angular Rate Sensor Visit the product page to see pricing options. Data Sheet
TECHNICAL SUPPORT SOFTWARE AND SYSTEMS REQUIREMENTS
Submit a technical question or find your regional support • IMU Evaluation Software for the EVAL-ADISx Platforms number. • USB Driver File for EVAL-ADISx Platforms (v2.2.95.68, 3/9/2016)
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Technical Articles
• Designing For Low Noise Feedback Control With Mems Gyroscopes
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Reading Sensor Data Output Data Registers Rotation Rate (Gyroscope) Internal Temperature Device Configuration Dual Memory Structure User Registers Digital Processing Configuration Internal Sample Rate Input Clock Configuration Digital Filtering Averaging/Decimation Filter Calibration Automatic Bias Correction (Autonull) Manual Bias Correction Restoring Factory Calibration Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Memory Management Checksum Test General-Purpose Input/Output Data Ready Input/Output Indicator Example Input/Output Configuration Automatic Self Test Power Management Status Product Identification Applications Information Power Supply Considerations Prototype Interface Board Installation Tips Packaging and Ordering Information Outline Dimensions Ordering Guide
