Datasheet ADXRS646 (Analog Devices) - 7
DescriptionHigh Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope
Pages / Page13 / 7 — ADXRS646. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. TION. P F O. T …
RevisionC
File Format / SizePDF / 595 Kb
ADXRS646. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. TION. P F O. T OF P. 8.5. 8.6. 8.7. 8.8. 8.9. 9.0. 9.1. 9.2. 9.3. 9.4. 9.5
ADXRS646 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS TION P F O T OF P 8.5 8.6 8.7 8.8 8.9 9.0 9.1 9.2 9.3 9.4 9.5
N > 1000 for all typical performance plots, unless otherwise noted.
30 35 30 25 ) ) % % ( ( 25 ON TION 20 TI LA LA U U 20 P P O 15 O P F O 15 T T OF P N 10 N E E C C 10 R R E E P P 5 5 0 0 75 80 85 90 95 00 05 10 15 20 25 8.5 8.6 8.7 8.8 8.9 9.0 9.1 9.2 9.3 9.4 9.5
010
2. 2. 2. 2. 2. 3. 3. 3. 3. 3. 3.
-004
SENSITIVITY (mV/°/sec) RATEOUT (V)
09771- 09771 Figure 4. Null Bias at 25°C Figure 7. Sensitivity at 25°C
30 10.5 25 ) 10.0 (% N IO T 20 sec) 9.5 A L V/°/ PU m ( 15 Y 9.0 PO T F IVI O T T N SI 10 E 8.5 C SEN PER 5 8.0 0 7.5 .30 .25 .20 .15 .10 .05 0 05 10 15 20 25 30 –50 –30 –10 10 30 50 70 90 110
-105
–0 –0 –0 –0 –0 –0 0. 0. 0. 0. 0. 0.
-005
TEMPERATURE (°C)
09771
DRIFT (°/sec/°C)
9771 0 Figure 5. Null Drift over Temperature Figure 8. Sensitivity over Temperature, 16 Parts in Sockets
3.5 1k 3.4 s) 3.3 rm our 3.2 °/H 100 ( ) 3.1 V ( TION L 3.0 IA V NUL 2.9 N DE A 10 2.8 L AL 2.7 T O RO 2.6 2.5
0
1 –60 –40 –20 0 20 40 60 80 100 120 140
-10
0.01 0.1 1 10 100 1k
012
TEMPERATURE (°C)
771 71- 09
AVERAGING TIME (Seconds)
097 Figure 6. Null Output over Temperature, 16 Parts in Sockets Figure 9. Typical Root Allan Deviation at 25°C vs. Averaging Time Rev. C | Page 6 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST MODIFYING THE MEASUREMENT RANGE IMMUNITY TO VIBRATION OUTLINE DIMENSIONS ORDERING GUIDE
