Datasheet ADXRS646 (Analog Devices) - 9
DescriptionHigh Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope
Pages / Page13 / 9 — ADXRS646. Data Sheet. ) %. N (. T A. EN C. RCE E. 2.8. 2.9. 3.0. 3.1. …
RevisionC
File Format / SizePDF / 595 Kb
ADXRS646. Data Sheet. ) %. N (. T A. EN C. RCE E. 2.8. 2.9. 3.0. 3.1. 3.2. 3.3. 3.4. CURRENT CONSUMPTION (mA). TEMP OUTPUT (V). 4.5. 4.0. 3.5. 2.5. (V) PM. 2.0
ADXRS646 Data Sheet ) % N ( T A EN C RCE E 2.8 2.9 3.0 3.1 3.2 3.3 3.4 CURRENT CONSUMPTION (mA) TEMP OUTPUT (V) 4.5 4.0 3.5 2.5 (V) PM 2.0
ADXRS646 Data Sheet 80 35 70 30 ) ) % (% 60 N N ( 25 IO IO T A 50 AT L UL 20 PU P 40 O PO P F F 15 O O T 30 NT EN C 10 R 20 RCE E PE P 10 5 0 0 70 75 80 85 90 95 00 05 10 15 20 25 30 2.8 2.9 3.0 3.1 3.2 3.3 3.4
013
2. 2. 2. 2. 2. 2. 3. 3. 3. 3. 3. 3. 3.
-009
V CURRENT CONSUMPTION (mA)
09771-
TEMP OUTPUT (V)
09771 Figure 16. VTEMP Output at 25°C Figure 18. Current Consumption at 25°C
4.5 4.0 3.5 3.0 2.5 (V) PM TE 2.0 V 1.5 1.0 0.5 0
2
–100 –50 0 50 100 150
-10
TEMPERATURE (°C)
771 09 Figure 17. VTEMP Output vs. Temperature Rev. C | Page 8 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST MODIFYING THE MEASUREMENT RANGE IMMUNITY TO VIBRATION OUTLINE DIMENSIONS ORDERING GUIDE
