Datasheet ADXRS646 (Analog Devices) - 6
Description | High Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope |
Pages / Page | 12 / 6 — ADXRS646-EP. Enhanced Product. TYPICAL PERFORMANCE CHARACTERISTICS. TION. … |
Revision | A |
File Format / Size | PDF / 349 Kb |
ADXRS646-EP. Enhanced Product. TYPICAL PERFORMANCE CHARACTERISTICS. TION. PER. 8.5. 8.6. 8.7. 8.8. 8.9. 9.0. 9.1. 9.2. 9.3. 9.4. 9.5
ADXRS646-EP Enhanced Product TYPICAL PERFORMANCE CHARACTERISTICS
N > 1000 for all typical performance plots, unless otherwise noted.
30 35 30 25 ) ) % % ( ( 25 20 TION TION A A L L 20 PU PU 15 PO PO F F 15 O O T T 10 EN EN C C 10 PER PER 5 5 0 0 75 80 85 90 95 00 05 10 15 20 25 8.5 8.6 8.7 8.8 8.9 9.0 9.1 9.2 9.3 9.4 9.5
010
2. 2. 2. 2. 2. 3. 3. 3. 3. 3. 3.
004
SENSITIVITY (mV/°/sec) RATEOUT (V)
10046- 10046- Figure 4. Null Bias at 25°C Figure 7. Sensitivity at 25°C
30 40 35 25 ) ) % % ( ( 30 20 TION TION A A 25 L L PU PU 15 20 PO PO F F O O T T 15 10 EN EN C C 10 PER PER 5 5 0 0 0
1 1
30 25 20 15 10 05 05 10 15 20 25 30 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 18 20
0
0. 0. 0. 0. 0. 0.
005
–0. –0. –0. –0. –0. –0. PERCENT DRIFT (%)
10046-
DRIFT (°/sec/°C)
10046- Figure 5. Null Drift over Temperature (VRATIO = 5 V) Figure 8. Sensitivity Drift over Temperature
3.5 1k 3.4 3.3 r rms) u 3.2 °/Ho 100 3.1 N ( (V) IO L T 3.0 IA V NUL 2.9 AN DE 10 2.8 L AL 2.7 OOT R 2.6 2.5 1 –60 –40 –20 0 20 40 60 80 100 120 140
100
0.01 0.1 1 10 100 1k
012
TEMPERATURE (°C)
10046-
AVERAGING TIME (Seconds)
10046- Figure 6. Null Output over Temperature, 16 Parts in Sockets (VRATIO = 5 V) Figure 9. Typical Root Allan Deviation at 25°C vs. Averaging Time Rev. A | Page 6 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
