Datasheet ADXRS646 (Analog Devices) - 7
Description | High Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope |
Pages / Page | 12 / 7 — Enhanced Product. ADXRS646-EP. TION. PER. 350. 370. 390. 410. 430. 450. … |
Revision | A |
File Format / Size | PDF / 349 Kb |
Enhanced Product. ADXRS646-EP. TION. PER. 350. 370. 390. 410. 430. 450. 470. 490. 510. 530. 550. 570. 590. 610. 630. 650. –650. –630. –610. –590. –570. –550. –530. –510. –490
Enhanced Product ADXRS646-EP 25 25 ) 20 ) % 20 % ( ( TION TION A A L 15 L 15 PU PU PO PO F F O 10 O 10 T T EN EN C C PER 5 PER 5 0 0
006
350 370 390 410 430 450 470 490 510 530 550 570 590 610 630 650
007
–650 –630 –610 –590 –570 –550 –530 –510 –490 –470 –450 –430 –410 –390 –370 –350 ST1Δ (mV) ST2Δ (mV)
10046- 10046- Figure 10. ST1 Output Change at 25°C (VRATIO = 5 V) Figure 13. ST2 Output Change at 25°C (VRATIO = 5 V)
–0.30 0.75 –0.35 0.70 –0.40 0.65 –0.45 0.60 –0.50 (V) 0.55 (V) 1Δ 2Δ –0.55 ST 0.50 ST –0.60 0.45 –0.65 0.40 –0.70 0.35 –0.75 0.30 –60 –40 –20 0 20 40 60 80 100 120 140
104
103
TEMPERATURE (°C) TEMPERATURE (°C)
10046- 10046- Figure 11. ST1 Output Change vs. Temperature, 16 Parts in Sockets Figure 14. ST2 Output Change vs. Temperature, 16 Parts in Sockets
70 9 0 COUT = 470pF 6 PHASE –10 60 ) % ) B 3 –20 ( 50 rees) TION SE (d 0 –30 A N Deg L MAGNITUDE ( 40 E PU –3 –40 ESPO NS PO O F P 30 E R –6 –50 S O D T U IT RE E EN –9 –60 N C 20 G HAS MA –12 –70 P PER 10 –15 –80 0 –18 –90 –4 –3 –2 –1 0 1 2 3 4
008
0.1 1 10
101
MISMATCH (%)
10046-
FREQUENCY (kHz)
10046- Figure 12. Self-Test Mismatch at 25°C (VRATIO = 5 V) Figure 15. ADXRS646-EP Frequency Response with a 2.2 kHz Output Filter Rev. A | Page 7 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
