Datasheet ADXRS649 (Analog Devices) - 2
DescriptionFast Starting, ±20,000°/sec Vibration Rejecting Rate Gyro
Pages / Page13 / 2 — ADXRS649* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
File Format / SizePDF / 347 Kb
ADXRS649* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXRS649* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADXRS649 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXRS649 Breakout Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADXRS649 EngineerZone Discussions. • ADXRS649: Fast Starting, ±20,000°/sec Vibration Rejecting Rate Gyro Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-306: Evaluating the Fast Starting, ±20,000°/sec Vibration Rejecting Yaw Rate Gyroscope with Analog
TECHNICAL SUPPORT
Output Submit a technical question or find your regional support number.
REFERENCE MATERIALS Technical Articles DOCUMENT FEEDBACK
• ADI Ups Ante in High-Precision MEMS Gyros Submit feedback for this data sheet. • MS-2158: Gyro Mechanical Performance: The Most Important Parameter
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting the Bandwidth Temperature Output and Calibration Modifying the Measurement Range Null Bias Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
