Datasheet ADXRS649 (Analog Devices) - 3
DescriptionFast Starting, ±20,000°/sec Vibration Rejecting Rate Gyro
Pages / Page13 / 3 — ADXRS649. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 10/12—Rev. A to …
File Format / SizePDF / 347 Kb
ADXRS649. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 10/12—Rev. A to Rev. B. 3/11—Rev. 0 to Rev. A
ADXRS649 Data Sheet TABLE OF CONTENTS REVISION HISTORY 10/12—Rev A to Rev B 3/11—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 5 link to page 5 link to page 5 link to page 6 link to page 7 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12
Features .. 1 Typical Performance Characteristics ..6 Applications ... 1 Theory of Operation ...9 General Description ... 1 Setting the Bandwidth ..9 Functional Block Diagram .. 1 Temperature Output and Calibration .. 10 Revision History ... 2 Modifying the Measurement Range .. 10 Specifications ... 3 Null Bias Adjustment ... 10 Absolute Maximum Ratings .. 4 Self-Test Function .. 10 Rate Sensitive Axis ... 4 Continuous Self-Test .. 10 ESD Caution .. 4 Outline Dimensions ... 11 Pin Configuration and Function Descriptions ... 5 Ordering Guide .. 11
Changes to Figure 1 .. 1 Changed Sensor Resonant Frequency Minimum Parameter from 16 kHz to 15.5 kHz ... 1 Changed Sensor Resonant Frequency Typical Parameter from 18 kHz to 17.5 kHz ... 3
Changes to Ordering Guide .. 11
12/10—Revision 0: Initial Version
Rev. B | Page 2 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting the Bandwidth Temperature Output and Calibration Modifying the Measurement Range Null Bias Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
