Datasheet ADXRS453 (Analog Devices) - 2
DescriptionHigh Performance, Digital Output Gyroscope
Pages / Page33 / 2 — ADXRS453* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 833 Kb
ADXRS453* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
ADXRS453* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• MS-2158: Gyro Mechanical Performance: The Most
EVALUATION KITS
Important Parameter • ADXRS453Z Evaluation Board • Real Time Eval System for Digital Output Sensor
DESIGN RESOURCES
• ADXRS453 Material Declaration
DOCUMENTATION
• PCN-PDN Information
Application Notes
• Quality And Reliability • AN-1073: Soldering Recommendations for the Ceramic • Symbols and Footprints Vertical Mount Package
Data Sheet DISCUSSIONS
• ADXRS453: High Performance, Digital Output Gyroscope View all ADXRS453 EngineerZone Discussions. Data Sheet
User Guides SAMPLE AND BUY
• UG-246: Evaluation Board for the ±300°/sec, Single-Axis Visit the product page to see pricing options. Digital Output Rate Gyroscope • UG-260: ADXRS450/ADXRS453 Sensor Evaluation System
TECHNICAL SUPPORT
Submit a technical question or find your regional support
SOFTWARE AND SYSTEMS REQUIREMENTS
number. • ADXRS453 - No-OS Driver for Microchip Microcontroller Platforms
DOCUMENT FEEDBACK
• ADXRS453 - No-OS Driver for Renesas Microcontroller Submit feedback for this data sheet. Platforms • ADXRS453 Pmod Xilinx FPGA Reference Design
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Rate Sensitive Axis ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Continuous Self-Test Mechanical Performance Noise Performance Applications Information Calibrated Performance Mechanical Considerations for Mounting Application Circuits ADXRS453 Signal Chain Timing SPI Communication Protocol Command/Response Device Data Latching SPI Timing Characteristics Command/Response Bit Definitions SQ2 to SQ0 Bits SM2 to SM0 Bits A8 to A0 Bits D15 to D0 Bits P Bit SPI Bit RE Bit DU Bit ST1 and ST0 Bits P0 Bit P1 Bit Fault Register Bit Definitions Fail Bit AMP Bit OV Bit UV Bit PLL Bit Q Bit NVM Bit POR Bit PWR Bit CST Bit CHK Bit Recommended Start-Up Sequence with CHK Bit Assertion Rate Data Format Memory Map and Registers Memory Map Memory Register Definitions Rate (RATEx) Registers Temperature (TEMx) Registers Low CST (LOCSTx) Registers High CST (HICSTx) Registers Quad Memory (QUADx) Registers Fault (FAULTx) Registers Part ID (PIDx) Registers Serial Number (SNx) Registers Package Orientation and Layout Information Solder Profile Package Marking Codes Outline Dimensions Ordering Guide
