Datasheet ADXRS652 (Analog Devices) - 5
Description±250°/sec Yaw Rate Gyro
Pages / Page13 / 5 — Table 2. RATE SENSITIVE AXIS. Parameter Rating. RATE. RATE OUT. AXIS. CC …
File Format / SizePDF / 356 Kb
Table 2. RATE SENSITIVE AXIS. Parameter Rating. RATE. RATE OUT. AXIS. CC = 5V. LONGITUDINAL. 4.75V. RATIO/2. RATE IN. A B C D E F G. 0.25V
Table 2 RATE SENSITIVE AXIS Parameter Rating RATE RATE OUT AXIS CC = 5V LONGITUDINAL 4.75V RATIO/2 RATE IN A B C D E F G 0.25V
ADXRS652 ABSOLUTE MAXIMUM RATINGS
Table 2. RATE SENSITIVE AXIS Parameter Rating
This is a Z-axis rate-sensing device (also called a yaw rate- Acceleration (Any Axis, 0.5 ms) sensing device). It produces a positive going output voltage Unpowered 2000 g for clockwise rotation about the axis normal to the package Powered 2000 g top, that is, clockwise when looking down at the package lid. VDD, AVCC −0.3 V to +6.0 V VRATIO AVCC
RATE RATE OUT
ST1, ST2 AVCC
AXIS V
Output Short-Circuit Duration Indefinite
CC = 5V
(Any Pin to Common)
LONGITUDINAL 4.75V AXIS +
Operating Temperature Range −55°C to +125°C
V 7 RATIO/2
Storage Temperature Range −65°C to +150°C
RATE IN 1
Stresses above those listed under the Absolute Maximum
A B C D E F G 0.25V A1
2 00 0- Ratings may cause permanent damage to the device. This is a
LATERAL AXIS GND
82 08 stress rating only; functional operation of the device at these or Figure 2. RATEOUT Signal Increases with Clockwise Rotation any other conditions above those indicated in the operational
ESD CAUTION
section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Drops onto hard surfaces can cause shocks of greater than 2000 g and can exceed the absolute maximum rating of the device. Care should be exercised in handling to avoid damage. Rev. A | Page 4 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION MODIFYING THE ADXRS652 SCALE TO MATCH THE ADXRS620 CALIBRATED PERFORMANCE ADXRS652 AND SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST OUTLINE DIMENSIONS ORDERING GUIDE
