Datasheet ADXRS624 (Analog Devices) - 8
Description±50°/s Yaw Rate Gyro
Pages / Page13 / 8 — ADXRS624. ( 30. TION. LA U. OP 20. PO F O T. T OF P 15. C R 10. PER. 2.40 …
RevisionA
File Format / SizePDF / 596 Kb
ADXRS624. ( 30. TION. LA U. OP 20. PO F O T. T OF P 15. C R 10. PER. 2.40 2.42 2.44 2.46 2.48 2.50 2.52 2.54 2.56 2.58 2.60
ADXRS624 ( 30 TION LA U OP 20 PO F O T T OF P 15 C R 10 PER 2.40 2.42 2.44 2.46 2.48 2.50 2.52 2.54 2.56 2.58 2.60
ADXRS624 30 40 35 25 ) ) % % ( ( 30 20 TION TION A 25 L LA U PU 15 OP 20 PO F O T T OF P 15 10 N EN E C C R 10 E PER P 5 5 0 0 2.40 2.42 2.44 2.46 2.48 2.50 2.52 2.54 2.56 2.58 2.60 50 54 58 62 66 70 74 78 82 86 90 94 98
010 013
MEASUREMENT RANGE (°/sec) V
08999-
TEMP OUTPUT (V)
08999- Figure 10. Measurement Range Figure 13. VTEMP Output at 25°C (VRATIO = 5 V)
2.5 3.3 2.0 3.1 1.5 2.9 1.0 2.7 (V) (V) T Δ 0.5 PU 2.5 EST T 0 U F-T O 2.3 P –0.5 SEL EM T 2.1 V –1.0 1.9 –1.5 –2.0 1.7 256 PARTS –2.5 1.5 –40 –20 0 20 40 60 80 100 120
011
014
TEMPERATURE (ºC) TEMPERATURE (°C)
08999- 08999- Figure 11. Typical Self-Test Change over Temperature Figure 14. VTEMP Output over Temperature (VRATIO = 5 V)
30 60 REF 50 Y ) 25 X % ( 40 +45° TION 20 –45° 30 LA U /s ° OP 15 20 OR g T OF P 10 N E 10 C R 0 E P 5 –10 0 –20 .5 .6 .7 .8 .9 .0 .1 .2 .3 .4 .5 .6 .7 .8 .9 .0 .1 .2 .3 .4 .5
012
750 770 790 810 830 850
015
2 2 2 2 2 3 3 3 3 3 3 3 3 3 3 4 4 4 4 4 4 (mA)
08999-
TIME (ms)
08999- Figure 12. Current Consumption at 25°C (VRATIO = 5 V) Figure 15. g and g × g Sensitivity for a 50 g, 10 ms Pulse Rev. A | Page 7 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate-Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Calibrated Performance ADXRS624 and Supply Ratiometricity Null Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide Automotive Products
