Datasheet ADIS16260, ADIS16265 (Analog Devices) - 6
DescriptionProgrammable Digital Gyroscope Sensor
Pages / Page20 / 6 — ADIS16260/ADIS16265. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. …
RevisionF
File Format / SizePDF / 405 Kb
ADIS16260/ADIS16265. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Rating. ESD CAUTION
ADIS16260/ADIS16265 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
link to page 6 link to page 6
ADIS16260/ADIS16265 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any Acceleration other conditions above those indicated in the operational Any Axis, Unpowered, 0.5 ms 2000 g section of this specification is not implied. Exposure to absolute Any Axis, Powered, 0.5 ms 2000 g maximum rating conditions for extended periods may affect VCC to GND −0.3 V to +6.0 V device reliability. Digital Input/Output Voltage to GND −0.3 V to +5.3 V Analog Inputs to GND −0.3 V to +3.5 V Operating Temperature Range1 −40°C to +125°C
ESD CAUTION
Storage Temperature Range1 −65°C to +150°C 1 Extended exposure to temperatures outside the temperature range of −40°C to +85°C can adversely affect the accuracy of the factory calibration. For best accuracy, store the part within the temperature range of −40°C to +85°C. Rev. E | Page 6 of 20 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Sensing Element Data Sampling and Processing User Interface SPI Interface User Registers Basic Operation SPI Write Commands SPI Read Commands Memory Map Processing Sensor Data Operational Controls Internal Sample Rate Sensor Bandwidth Digital Filtering Dynamic Range Calibration Global Commands Power Management Input/Output Functions General-Purpose I/O Data Ready I/O Indicator Auxiliary DAC Diagnostics Self-Test Memory Test Status Alarm Registers Product Identification Applications Information Assembly Bias Optimization Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
