Datasheet ADIS16060 (Analog Devices) - 2
DescriptionWide Bandwidth Yaw Rate Gyroscope with SPI
Pages / Page13 / 2 — ADIS16060* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 309 Kb
ADIS16060* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16060* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16060 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16060 Daughter Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADIS16060 EngineerZone Discussions. • AN-1049: Calibrating iMEMS® Gyroscopes • AN-918: Motionless Bandwidth Test for MEMS Sensors
SAMPLE AND BUY
• AN-942: Optimizing MEMS Gyroscope Performance with Visit the product page to see pricing options. Digital Control
Data Sheet TECHNICAL SUPPORT
• ADIS16060: Wide Bandwidth Yaw Rate Gyroscope with SPI Submit a technical question or find your regional support Datasheet number.
SOFTWARE AND SYSTEMS REQUIREMENTS DOCUMENT FEEDBACK
• ADIS16060 IIO Yaw Rate Gyroscope Linux Driver Submit feedback for this data sheet.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Analog-to-Digital Converter Input Rate Sensitive Axis Basic Operation Serial Peripheral Interface (SPI) Selecting Output Data Output Data Access Output Data Formatting ADC Conversion Applications Information Supply And Common Considerations Setting Bandwidth Increasing Measurement Range Dynamic Digital Sensitivity Scaling Temperature Measurements Self-Test Function Outline Dimensions Ordering Guide
