Wideband Monolithic AmplifierAVM-273HP+Characterization Test CircuitVCM-1+ Click Here1 Auto Voltage Sequencing Module Fig. 1 Schematic of Test Board TBD (Test & Application) TBD incorporates Current stabilization, automatic voltage sequencing, reverse voltage protection circuitry. Test board used for characterization. (DUT soldered on Mini-Circuits Characterization Test Board TBD) Gain, Output power at 1dB compression (P1dB), Noise Figure, Output IP3 (OIP3) are measured using Agilent’s N5242A PNA-X microwave network analyzer. Conditions: 1. Gain: Pin=-25 dBm 2. Output IP3 (OIP3): Two tones, spaced 1 MHz apart, 0 dBm/tone at output. 3. V+ set to +6.1V to account for 1.1V drop in bias circuit resulting in +5V at drain (VD1 to VD3 (A&B)) 4. V- is set to -5V to realize proper gate voltage (-0.8V typ.) NOTE 1: The voltage sequencing and DC control circuit is available as a self-contained, surface mount module, see page 7Product Marking black body MCL index over pin 1 AVM27 model family designation Notes A. Performance and quality attributes and conditions not expressly stated in this specification document are intended to be excluded and do not form a part of this specification document. B. Electrical specifications and performance data contained in this specification document are based on Mini-Circuit’s applicable established test performance criteria and measurement instructions. C. The parts covered by this specification document are subject to Mini-Circuits standard limited warranty and terms and conditions (collectively, “Standard Terms”); Purchasers of this part are entitled to the rights and benefits contained therein. For a full statement of the Standard Terms and the exclusive rights and remedies thereunder, please visit Mini-Circuits’ website at www.minicircuits.com/MCLStore/terms.jsp Mini-Circuits ® www.minicircuits.com P.O. Box 350166, Brooklyn, NY 11235-0003 (718) 934-4500 sales@minicircuits.com Page 5 of 7 Document Outline AVM-273HP+ Data Sheet View Data View Graphs Case Style PCB Layout Eval Board Enviromental Ratings
