Datasheet ERA-5+ Full Version (Mini-Circuits) - 8
ManufacturerMini-Circuits
DescriptionDrop-In Monolithic Amplifier DC-4 GHz
Pages / Page23 / 8 — MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. …
MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. FREQ. Gain. Isolation. Return. Stability. Comp. Figure. Loss. (MHz). (dB). Delta. (dBm)
MMIC Amplifier ERA-5+ Definitions: Input Output 1dB IP3 Noise FREQ Gain Isolation Return Stability Comp Figure Loss (MHz) (dB) Delta (dBm)
Typical Performance Data
Definitions:
Input Return Loss = -S11 (dB) Gain(Power Gain) = S21 (dB) Reverse Isolation = -S12 (dB) Output Return Loss = -S22 (dB) TEST CONDITIONS: Icc = 65mA, Vd = 5.01V @Temperature = -45degC
Input Output 1dB IP3 Noise FREQ Gain Isolation Return Return Stability FREQ Comp. Output Figure Loss Loss Output (MHz) (dB) (dB) (dB) (dB) K Delta (MHz) (dBm) (dBm) (dB)
50 20.77 24.17 24.15 41.36 1.07 0.68 50 35.57 18.65 2.50 100 20.76 24.13 24.00 42.05 1.07 0.68 100 35.98 18.62 2.53 200 20.68 24.09 23.32 40.19 1.07 0.68 200 36.04 18.57 2.46 300 20.59 24.04 23.62 43.61 1.08 0.67 300 36.05 18.61 2.63 400 20.49 24.04 23.70 46.55 1.08 0.66 400 35.74 18.53 2.59 500 20.36 23.95 23.31 46.69 1.08 0.66 500 35.56 18.53 2.60 600 20.22 23.87 23.07 44.89 1.09 0.66 600 35.53 18.45 2.62 700 20.06 23.78 22.88 42.27 1.09 0.65 700 35.75 18.44 2.55 800 19.90 23.71 22.63 41.35 1.09 0.64 800 35.81 18.41 2.51 900 19.71 23.61 22.34 40.11 1.10 0.64 900 35.70 18.26 2.52 1000 19.52 23.50 22.25 38.14 1.10 0.63 1000 35.50 18.23 2.55 1100 19.33 23.40 22.18 36.64 1.11 0.62 1100 35.26 18.27 2.53 1200 19.12 23.28 21.85 36.32 1.11 0.62 1200 35.10 18.23 2.59 1300 18.92 23.15 21.88 35.50 1.11 0.61 1300 34.68 18.18 2.57 1400 18.71 23.02 21.94 34.25 1.12 0.61 1400 34.31 18.17 2.56 1500 18.51 22.89 22.12 33.06 1.12 0.60 1500 34.16 18.12 2.53 1600 18.29 22.74 21.96 32.65 1.13 0.60 1600 34.35 18.06 2.46 1700 18.07 22.60 22.20 31.67 1.13 0.59 1700 34.49 18.08 2.44 1800 17.86 22.45 22.45 30.74 1.14 0.59 1800 33.94 17.95 2.49 2000 17.44 22.15 22.41 30.21 1.14 0.58 1900 33.44 17.83 2.49 2100 17.22 22.02 22.57 29.45 1.15 0.57 2000 33.10 17.69 2.57 2200 17.02 21.86 22.85 28.63 1.15 0.57 2100 32.69 17.58 2.51 2400 16.61 21.53 23.24 27.34 1.16 0.56 2200 32.22 17.50 2.43 2600 16.20 21.19 22.61 26.99 1.16 0.56 2300 31.81 17.42 2.49 2800 15.76 20.91 22.45 26.72 1.17 0.55 2400 31.55 17.20 2.55 3000 15.40 20.56 22.08 25.67 1.17 0.55 2500 31.27 16.90 2.60 3200 15.02 20.25 21.43 25.29 1.17 0.54 2600 31.13 16.66 2.56 3400 14.69 19.86 21.29 23.83 1.17 0.55 2700 31.08 16.58 2.57 3600 14.32 19.58 21.49 23.18 1.17 0.54 2800 30.99 16.31 2.61 4000 13.71 18.90 20.76 21.92 1.16 0.54 2900 30.75 16.16 2.53 4500 12.87 18.13 22.29 18.48 1.17 0.54 3000 30.46 16.01 2.57 5000 12.23 17.49 21.62 17.32 1.16 0.54 3100 30.06 15.70 2.55 6000 11.02 16.26 16.65 13.16 1.14 0.56 3200 29.63 15.55 2.63 7000 9.93 15.19 11.83 9.91 1.09 0.60 3300 29.36 15.36 2.59 8000 8.77 14.30 8.13 7.33 1.02 0.64 3400 29.07 15.19 2.66 9000 7.36 13.76 6.29 6.15 0.96 0.63 3500 28.94 14.80 2.63 10000 5.10 13.22 5.29 5.28 0.97 0.59 3600 28.74 14.67 2.72 11000 2.49 13.28 4.44 4.36 1.00 0.55 3700 28.48 14.44 2.65 12000 0.25 12.95 4.21 4.22 1.04 0.49 3800 28.28 14.27 2.72 13000 -1.10 12.47 4.18 4.35 0.99 0.40 4000 27.58 13.94 2.63 REV. X1 ERA-5+ 120123 Page 4 of 11 Document Outline ERA-5+ Data Sheet View Data View Graphs Case Style Tape and Reel PCB Layout Eval Board Enviromental Ratings
