Datasheet ERA-5+ Full Version (Mini-Circuits) - 9
Manufacturer | Mini-Circuits |
Description | Drop-In Monolithic Amplifier DC-4 GHz |
Pages / Page | 23 / 9 — MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. … |
File Format / Size | PDF / 1.3 Mb |
MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. FREQ. Gain. Isolation. Return. Stability. Comp. Figure. Loss. (MHz). (dB). Delta. (dBm)
MMIC Amplifier ERA-5+
Typical Performance Data
Definitions:
Input Return Loss = -S11 (dB) Gain(Power Gain) = S21 (dB) Reverse Isolation = -S12 (dB) Output Return Loss = -S22 (dB) TEST CONDITIONS: Icc = 52mA, Vd = 4.93V @Temperature = -45degC
Input Output 1dB IP3 Noise FREQ Gain Isolation Return Return Stability FREQ Comp. Output Figure Loss Loss Output (MHz) (dB) (dB) (dB) (dB) K Delta (MHz) (dBm) (dBm) (dB)
50 20.62 23.98 22.54 32.90 1.07 0.68 50 31.99 16.82 2.38 100 20.60 23.95 22.36 33.02 1.07 0.68 100 32.30 16.67 2.45 200 20.53 24.00 21.88 32.04 1.08 0.67 200 32.30 16.62 2.40 300 20.44 23.94 22.20 33.86 1.08 0.67 300 32.36 16.69 2.55 400 20.34 23.90 22.33 36.24 1.08 0.66 400 32.09 16.71 2.56 500 20.22 23.83 22.11 36.71 1.08 0.66 500 32.13 16.68 2.53 600 20.08 23.75 22.01 37.47 1.09 0.66 600 32.18 16.58 2.57 700 19.93 23.68 21.92 39.64 1.09 0.65 700 32.61 16.53 2.51 800 19.77 23.60 21.76 42.52 1.09 0.64 800 32.89 16.57 2.42 900 19.59 23.50 21.59 43.67 1.10 0.64 900 32.98 16.42 2.42 1000 19.39 23.40 21.58 47.60 1.10 0.63 1000 32.94 16.48 2.49 1100 19.21 23.28 21.56 52.10 1.11 0.63 1100 32.82 16.53 2.43 1200 19.01 23.16 21.31 50.85 1.11 0.62 1200 32.82 16.47 2.50 1300 18.81 23.04 21.38 46.06 1.11 0.61 1300 32.67 16.41 2.52 1400 18.61 22.92 21.46 41.56 1.12 0.61 1400 32.52 16.34 2.47 1500 18.41 22.79 21.64 38.11 1.12 0.60 1500 32.47 16.36 2.45 1600 18.19 22.66 21.55 37.18 1.13 0.60 1600 32.75 16.33 2.41 1700 17.97 22.53 21.76 35.22 1.13 0.59 1700 33.11 16.50 2.39 1800 17.77 22.38 22.00 33.50 1.14 0.59 1800 32.69 16.48 2.40 2000 17.35 22.08 21.96 32.11 1.14 0.58 1900 32.28 16.48 2.46 2100 17.13 21.95 22.12 31.21 1.15 0.57 2000 32.06 16.51 2.49 2200 16.93 21.80 22.34 30.04 1.15 0.57 2100 31.75 16.55 2.45 2400 16.52 21.48 22.62 28.33 1.16 0.56 2200 31.40 16.40 2.37 2600 16.12 21.15 21.97 27.71 1.16 0.56 2300 31.22 16.26 2.41 2800 15.69 20.89 21.81 27.36 1.17 0.55 2400 30.96 16.14 2.49 3000 15.33 20.54 21.38 26.12 1.17 0.54 2500 30.72 16.05 2.54 3200 14.95 20.21 20.80 25.69 1.17 0.54 2600 30.53 15.89 2.49 3400 14.62 19.83 20.62 24.09 1.17 0.54 2700 30.57 15.87 2.49 3600 14.25 19.55 20.83 23.47 1.17 0.54 2800 30.38 15.63 2.52 4000 13.63 18.89 20.10 22.19 1.17 0.54 2900 30.19 15.47 2.48 4500 12.79 18.14 21.39 18.74 1.17 0.53 3000 29.95 15.35 2.51 5000 12.15 17.52 20.71 17.56 1.17 0.53 3100 29.53 15.08 2.49 6000 10.93 16.31 16.13 13.38 1.14 0.55 3200 29.16 14.95 2.53 7000 9.83 15.25 11.53 10.11 1.10 0.58 3300 28.89 14.78 2.52 8000 8.65 14.37 7.96 7.54 1.02 0.63 3400 28.54 14.59 2.56 9000 7.22 13.84 6.18 6.34 0.97 0.62 3500 28.42 14.22 2.55 10000 4.96 13.29 5.22 5.45 0.98 0.58 3600 28.22 14.09 2.62 11000 2.35 13.34 4.39 4.49 1.02 0.54 3700 28.03 13.88 2.57 12000 0.11 13.01 4.17 4.32 1.05 0.48 3800 27.79 13.69 2.62 13000 -1.26 12.52 4.13 4.40 0.99 0.40 4000 27.09 13.33 2.56 REV. X1 ERA-5+ 120123 Page 5 of 11 Document Outline ERA-5+ Data Sheet View Data View Graphs Case Style Tape and Reel PCB Layout Eval Board Enviromental Ratings
