Datasheet ADA4841-2KGD (Analog Devices) - 6
DescriptionLow Power, Low Noise and Distortion, Rail-to-Rail Output Amplifier
Pages / Page9 / 6 — ADA4841-2KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 4. …
File Format / SizePDF / 164 Kb
ADA4841-2KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
ADA4841-2KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
ADA4841-2KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Supply Voltage 12.6 V or any other conditions above those indicated in the operational Common-Mode Input Voltage −VS − 0.5 V to +VS + 0.5 V section of this specification is not implied. Operation beyond Differential Input Voltage ±1.8 V the maximum operating conditions for extended periods may Storage Temperature Range −65°C to +125°C affect product reliability. Junction Temperature 150°C
ESD CAUTION
Rev. A | Page 6 of 9 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY 5 V SUPPLY 3 V SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
