Datasheet AD8629-EP (Analog Devices) - 6
Description | Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifier |
Pages / Page | 8 / 6 — AD8629-EP. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 700. S = 5V. … |
File Format / Size | PDF / 249 Kb |
AD8629-EP. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 700. S = 5V. +85°C. 600. A) p 500. NT E. 400. CUR 30. CURR. AS 300. UT 20. +25°C. 200. INP
AD8629-EP Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 60 700 V V S = 5V S = 5V +85°C 600 50 A) A) p 500 (p ( 40 NT NT E RE 400 CUR 30 CURR AS AS 300 BI BI UT 20 UT P +25°C 200 IN INP 10 –40°C 100 0
5 02
0
0 00
0 1 2 3 4 5 6 –75 –25 +25 +75 +125
0-89
INPUT COMMON-MODE VOLTAGE (V)
2890- 1
TEMPERATURE (°C)
12 Figure 2. Input Bias Current vs. Input Common-Mode Voltage Figure 5. Input Bias Current vs. Temperature
+150 +150 V +I S = 2.7V SC V +I S = 5V SC A) –ISC A) –I m SC ( +100 m ( +100 NT NT +50 +50 CURRE T CURRE T UI RC 0 CUI 0 R -CI -CI RT RT O –50 H –50 HO S S UT P UT –100 P –100 UT UT O O
3
–150
6 00
–150
00 0-
–75 –25 +25 +75 +125 –75 –25 +25 +75 +125
0- 89
TEMPERATURE (°C)
89 12
TEMPERATURE (°C)
12 Figure 3. Output Short-Circuit Current vs. Temperature (2.7 V) Figure 6. Output Short-Circuit Current vs. Temperature (5 V)
1k 1k VCC – VOH @ 1kΩ VCC – VOH @ 100kΩ VCC – VOH @ 1kΩ VCC – VOH @ 100kΩ V V V V ) OL – VEE @ 1kΩ OL – VEE @ 100kΩ OL – VEE @ 1kΩ OL – VEE @ 100kΩ V V ) V VCC – VOH @ 10kΩ m CC – VOH @ 10kΩ ( 100 V m VOL – VEE @ 10kΩ E OL – VEE @ 10kΩ ( 100 E G A G A LT LT O O IL V 10 10 A IL V R A R O- O- -T T -T U T U TP 1 1 U TP U O O VS = 2.7V VS = 5V 0.1 0.1
-004
-007
890
TEMPERATURE (°C)
890 12
TEMPERATURE (°C)
12 Figure 4. Output-to-Rail Voltage vs. Temperature (2.7 V) Figure 7. Output-to-Rail Voltage vs. Temperature (5 V) Rev. A | Page 6 of 8 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—VS = 5.0 V ELECTRICAL CHARACTERISTICS—VS = 2.7 V ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
