Datasheet AD8039-EP (Analog Devices) - 4
DescriptionLow Power, 350 MHz Voltage Feedback Amplifier
Pages / Page8 / 4 — AD8039-EP. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 238 Kb
AD8039-EP. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8039-EP Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
AD8039-EP
TA = 25°C, VS = 5 V, RL = 2 kΩ to VS/2, gain = +1, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VOUT = 0.2 V p-p, TMIN to TMAX 275 300 MHz G = +2, VOUT = 0.2 V p-p 150 MHz G = +1, VOUT = 2 V p-p 30 MHz Bandwidth for 0.1 dB Flatness G = +2, VOUT = 0.2 V p-p 45 MHz Slew Rate G = +1, VOUT = 2 V step, RL = 2 kΩ 340 365 V/μs TMIN to TMAX 275 305 V/μs Overdrive Recovery Time G = +2, 1 V overdrive 50 ns Settling Time to 0.1% G = +2, VOUT = 2 V step 18 ns NOISE/HARMONIC PERFORMANCE SFDR Second Harmonic fC = 1 MHz, VOUT = 2 V p-p, RL = 2 kΩ −82 dBc Third Harmonic fC = 1 MHz, VOUT = 2 V p-p, RL = 2 kΩ −79 dBc Second Harmonic fC = 5 MHz, VOUT = 2 V p-p, RL = 2 kΩ −60 dBc Third Harmonic fC = 5 MHz, VOUT = 2 V p-p, RL = 2 kΩ −67 dBc Crosstalk, Output-to-Output f = 5 MHz, G = +2 −70 dB Input Voltage Noise f = 100 kHz 8 nV/√Hz Input Current Noise f = 100 kHz 600 fA/√Hz DC PERFORMANCE Input Offset Voltage TA = 25°C 0.8 3 mV TMIN to TMAX 4.5 mV Input Offset Voltage Drift 3 μV/°C Input Bias Current TA = 25°C 400 750 nA TMIN to TMAX 2.0 μA Input Bias Current Drift 3 nA/°C Input Offset Current ±30 nA Open-Loop Gain VOUT = ±2.5 V 70 dB INPUT CHARACTERISTICS Input Resistance 10 MΩ Input Capacitance 2 pF Input Common-Mode Voltage Range RL = 1 kΩ 1.0 to 4.0 V Common-Mode Rejection Ratio VCM = ±1 V, TA = 25°C 59 65 dB VCM = ±1 V, TMIN to TMAX 59 dB OUTPUT CHARACTERISTICS DC Output Voltage Swing RL = 2 kΩ, saturated output 0.9 to 4.1 V Capacitive Load Drive 30% overshoot, G = +2 20 pF POWER SUPPLY Operating Range 3 12 V Quiescent Current per Amplifier TA = 25°C 0.9 1.5 mA Power Supply Rejection Ratio TMIN to TMAX 65 71 dB Rev. 0 | Page 4 of 8 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
