Datasheet AD8037 (Analog Devices) - 7
DescriptionLow Distortion, Wide Bandwidth Voltage Feedback Clamp Amps
Pages / Page13 / 7 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16612
File Format / SizePDF / 149 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16612
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit TA type Min Max Clamp performance – continued. Clamp input bandwidth VCH or VCL = 2 Vpp +25C 01 180 MHz (-3 dB) 270 typical Clamp overshoot 2x overdrive, VCH or VCL = 2 VPP +25C 01 5 % 1 typical Overdrive recovery 2x overdrive +25C 01 1.3 typical ns DC performance RL = 150 , measured at AV = 50 Input offset voltage 5/ VIO +25C 01 7 mV 2 typical -55C to 105C 10 Offset voltage drift +25C 01 10 typical V/C Input bias current IIB +25C 01 9 A 3 typical -55C to 105C 15 Input offset current IIO +25C 01 3 A 0.1 typical -55C to 105C 5 Common mode CMRR VCM = 2 V +25C 01 70 dB rejection ratio 90 typical Open loop gain VOUT = 2.5 V +25C 01 54 dB 60 typical -55C to 105C 46 See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16612
REV PAGE 7
