Datasheet AD813 (Analog Devices) - 6
DescriptionSingle Supply, Low Power Triple Video Amplifier
Pages / Page11 / 6 — STANDARD. 5962-95596. MICROCIRCUIT DRAWING
File Format / SizePDF / 109 Kb
STANDARD 5962-95596 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – Continued. Conditions Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits Unit unless otherwise specified subgroups type Min Max Common mode rejection CMRR VS = +5 V, 0 V 1,2,3 01 -4000 4000 µV/V ratio, VOS VS = -5 V, +5 V -2500 2500 VS = -15 V, +15 V -2500 2500 Common mode rejection IBRR VS = +5 V, 0 V 1,2,3 01 -20 20 µA/V ratio, -IIB VS = -5 V, +5 V -20 20 VS = -15 V, +15 V -20 20 Power supply rejection PSRR V 1,2,3 01 -1000 1000 µV/V S = +5 V, 0 V, ratio, VOS VS = -15 V, +15 V Power supply rejection IBSR V 1,2,3 01 -10 10 µA/V S = +5 V, 0 V, ratio, -IIB VS = -15 V, +15 V Transresistance X 1,2,3 01 20 µA/V RES VS = +5 V, 0 V, RL = 1 kΩ V 20 S = -5 V, +5 V, RL = 1 kΩ V 20 S = -15 V, +15 V, RL = 1 kΩ Gain K V 1,2,3 01 1100 µV/V S = +5 V, 0 V, RL = 1 kΩ V 1300 S = -5 V, +5 V, RL = 1 kΩ V 500 S = -15 V, +15 V, RL = 1 kΩ 1/ Disable mode operation. Pulling the voltage on any one of the DISABLE pins 4 volts down from the positive supply will put the corresponding amplifier into a disabled, powered down state. In this condition the amplifier's quiescent supply current drops, its output becomes a high impedance, and there is a high level of isolation from input to output. Leaving the DISABLE pins disconnected (floating) will leave the corresponding amplifier operational, in the enabled state.
STANDARD
SIZE
5962-95596 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C 6 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
