Datasheet AD822-EP (Analog Devices)
Description | Single-Supply, Rail-to-Rail Low Power FET-Input Op Amp |
Pages / Page | 20 / 1 — Single-Supply, Rail-to-Rail. Low Power FET-Input Op Amp. AD822-EP. … |
File Format / Size | PDF / 321 Kb |
Single-Supply, Rail-to-Rail. Low Power FET-Input Op Amp. AD822-EP. FEATURES. CONNECTION DIAGRAM. True single-supply operation
Single-Supply, Rail-to-Rail Low Power FET-Input Op Amp AD822-EP FEATURES CONNECTION DIAGRAM True single-supply operation OUT1 1 8 V+ Input voltage range extends below ground Output swings rail-to-rail –IN1 2 7 OUT2 Single-supply capability from 5 V to 30 V +IN1 3 6 –IN2 Dual-supply capability from ±2.5 V to ±15 V
01
V– 4 5 +IN2
0 8-
AD822-EP
20
High load drive
09
Capacitive load drive of 350 pF, G = +1
Figure 1. 8-Lead SOIC_N (R Suffix)
Minimum output current of 15 mA GENERAL DESCRIPTION Excellent ac performance for low power
The AD822-EP is a dual precision, low power FET input op
800 μA maximum quiescent current per amplifier
amp that can operate from a single supply of 5 V to 30 V or dual
Unity-gain bandwidth: 1.8 MHz
supplies of ±2.5 V to ±15 V. It has true single-supply capability
Slew rate of 3 V/μs
with an input voltage range extending below the negative rail,
Good dc performance
allowing the AD822 to accommodate input signals below
800 μV maximum input offset voltage
ground in the single-supply mode. Output voltage swing
2 μV/°C typical offset voltage drift
extends to within 10 mV of each rail, providing the maximum
25 pA maximum input bias current
output dynamic range.
Low noise 13 nV/√Hz @ 10 kHz 100 No phase inversion ) ENHANCED PRODUCT FEATURES √Hz V/ Supports defense and aerospace applications (AQEC (n standard) ISE O Military temperature range (−55°C to +125°C) E N 10 G Controlled manufacturing baseline A T L One assembly/test site VO T One fabrication site PU Enhanced product change notification IN Qualification data available on request APPLICATIONS 1
02
10 100
0
1k 10k FREQUENCY (Hz)
9208- 0
Photodiode preamps
Figure 2. Input Voltage Noise vs. Frequency
Active filters 12-bit to 14-bit data acquisition systems
Offset voltage of 800 μV maximum, offset voltage drift of 2 μV/°C,
Low power references and regulators
input bias currents below 25 pA, and low input voltage noise provide dc precision with source impedances up to a gigaohm. The 1.8 MHz unity-gain bandwidth, –93 dB THD at 10 kHz, and 3 V/μs slew rate are provided with a low supply current of 800 μA per amplifier.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
