Datasheet AD822 (Analog Devices) - 6
DescriptionSingle-Supply, Rail-to-Rail Low Power FET-Input Dual Op Amp
Pages / Page17 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12636
File Format / SizePDF / 101 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12636
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit VS = 0 V, 5 V, TA type VCM = 0 V, VOUT = 0.2 V Min Max unless otherwise specified Dynamic performance. Unity gain frequency +25C 01 1.8 typical MHz Full power response VOUTpp = 4.5 V +25C 01 210 typical kHz Slew rate SR +25C 01 3 typical V/s Settling time tS To 0.1%, VOUT = 0.2 V to 4.5 V +25C 01 1.4 typical s To 0.01%, VOUT = 0.2 V to 4.5 V 1.8 typical Matching characteristics. Initial offset voltage VIO +25C 01 1.0 mV -55C to +125C 1.6 Initial offset voltage VIO +25C 01 3 typical V/ drift C Input bias current IIB +25C 01 20 pA Crosstalk CT At f = 1 kHz, RL = 5 k +25C 01 -130 typical dB At f = 100 kHz, RL = 5 k -93 typical Input characteristics. Input voltage range 2/ -55C to +125C 01 -0.2 +4 V Common mode CMRR VCM = 0 V to 2 V +25C 01 66 dB rejection ratio -55C to +125C 66 Differential input Z +25C 01 1013||0.5 typical ||pF impedance Common mode input Z +25C 01 1013||2.8 typical ||pF impedance See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12636
REV A PAGE 6
