Datasheet OP290 (Analog Devices) - 8
DescriptionLow Voltage Dual Precision, Micropower Op Amp
Pages / Page10 / 8 — STANDARD. 5962-89783. MICROCIRCUIT DRAWING
File Format / SizePDF / 100 Kb
STANDARD 5962-89783 MICROCIRCUIT DRAWING
TABLE II. Electrical test requirements. MIL-STD-883 test requirements Subgroups (in accordance with MIL-STD-883, method 5005, table I) Interim electrical parameters 1 (method 5004) Final electrical test parameters 1*,2,3,4,5,6 (method 5004) Group A test requirements 1,2,3,4,5,6,7,8 (method 5005) Groups C and D end-point electrical parameters 1 (method 5005) * PDA applies to subgroup 1. 4.3 Quality conformance inspection. Quality conformance inspection shall be in accordance with method 5005 of MIL-STD- 883 including groups A, B, C, and D inspections. The following additional criteria shall apply. 4.3.1 Group A inspection. a. Tests shall be as specified in table II herein. b. Subgroups 9, 10, and 11 in table I, method 5005 of MIL-STD-883 shall be omitted. 4.3.2 Groups C and D inspections. a. End-point electrical parameters shall be as specified in table II herein. b. Steady-state life test conditions, method 1005 of MIL-STD-883. (1) Test condition A, B, C, or D. The test circuit shall be maintained by the manufacturer under document revision level control and shall be made available to the preparing or acquiring activity upon request. The test circuit shall specify the inputs, outputs, biases, and power dissipation, as applicable, in accordance with the intent specified in method 1005 of MIL-STD-883. (2) TA = +125°C, minimum. (3) Test duration: 1,000 hours, except as permitted by method 1005 of MIL-STD-883. 5. PACKAGING 5.1 Packaging requirements. The requirements for packaging shall be in accordance with MIL-PRF-38535, appendix A. 6. NOTES 6.1 Intended use. Microcircuits conforming to this drawing are intended for use for Government microcircuit applications (original equipment), design applications, and logistics purposes. 6.2 Replaceability. Microcircuits covered by this drawing will replace the same generic device covered by a contractor- prepared specification or drawing.
STANDARD
SIZE
A 5962-89783 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 B
8
DSCC FORM 2234 APR 97
