Datasheet OP290 (Analog Devices) - 10
DescriptionLow Voltage Dual Precision, Micropower Op Amp
Pages / Page10 / 10 — STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 11-06-07. Approved. …
File Format / SizePDF / 100 Kb
STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 11-06-07. Approved. sources. of. supply. for. SMD. 5962-89783. are. listed. below. for. immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 11-06-07 Approved sources of supply for SMD 5962-89783 are listed below for immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 11-06-07 Approved sources of supply for SMD 5962-89783 are listed below for immediate acquisition information only and shall be added to MIL-HDBK-103 and QML-38535 during the next revision. MIL-HDBK-103 and QML-38535 will be revised to include the addition or deletion of sources. The vendors listed below have agreed to this drawing and a certificate of compliance has been submitted to and accepted by DLA Land and Maritime -VA. This information bulletin is superseded by the next dated revision of MIL-HDBK-103 and QML-38535. DLA Land and Maritime maintains an online database of all current sources of supply at http://www.dscc.dla.mil/Programs/Smcr/. Standard Vendor Vendor microcircuit drawing CAGE similar PIN 1/ number PIN 2/ 5962-8978301PA 3/ OP290AZ/883 5962-89783012A 3/ OP290ARC/883 1/ The lead finish shown for each PIN representing a hermetic package is the most readily available from the manufacturer listed for that part. If the desired lead finish is not listed contact the vendor to determine its availability. 2/ Caution. Do not use this number for item acquisition. Items acquired to this number may not satisfy the performance requirements of this drawing. 3/ Not available from an approved source of supply. The last known supplier is listed below. Vendor CAGE Vendor name number and address 24355 Analog Devices RT 1 Industrial Park P.O. Box 9106 Norwood, MA 02062 Point of contact: 7910 Triad Center Drive Greensboro, NC 27409-9605 The information contained herein is disseminated for convenience only and the Government assumes no liability whatsoever for any inaccuracies in the information bulletin.
