Datasheet AD712-EP (Analog Devices) - 3
DescriptionDual Precision, Low Cost, High Speed BiFET Op Amp
Pages / Page12 / 3 — Table 1. Parameter Min. Typ. Max. Unit
File Format / SizePDF / 206 Kb
Table 1 Parameter Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 AD712-EP SPECIFICATIONS VS = ±15 V @ TA = 25°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit
INPUT OFFSET VOLTAGE1 Initial Offset 0.3 3 mV TMIN to TMAX 4 mV vs. Temperature 7 20 μV/°C vs. Supply 76 95 dB TMIN to TMAX 76 dB Long-Term Offset Stability 15 μV/month INPUT BIAS CURRENT2 VCM = 0 V 25 75 pA VCM = 0 V @ TMAX 26 77 nA VCM = ±10 V 100 pA INPUT OFFSET CURRENT VCM = 0 V 10 25 pA VCM = 0 V @ TMAX 11 26 nA MATCHING CHARACTERISTICS Input Offset Voltage 3 mV TMIN to TMAX 4 mV Input Offset Voltage Drift 20 μV/°C Input Bias Current 25 pA Crosstalk At f = 1 kHz 120 dB At f = 100 kHz 90 dB FREQUENCY RESPONSE Small Signal Bandwidth 3.0 4.0 MHz Full Power Response 200 kHz Slew Rate 16 20 V/μs Settling Time to 0.01% 1.0 1.2 μs Total Harmonic Distortion 0.0003 % INPUT IMPEDANCE Differential 3 × 1012||5.5 Ω||pF Common Mode 3 × 1012||5.5 Ω||pF INPUT VOLTAGE RANGE Differential3 ±20 V Common-Mode Voltage4 +14.5, −11.5 V TMIN to TMAX −VS + 4 +VS − 2 V Common-Mode Rejection Ratio VCM = ±10 V 76 88 dB TMIN to TMAX 76 84 dB VCM = ±11 V 70 84 dB TMIN to TMAX 70 80 dB INPUT VOLTAGE NOISE 0.1 Hz to 10 Hz 2 μV p-p f = 10 Hz 45 nV/√Hz f = 100 Hz 22 nV/√Hz f = 1 kHz 18 nV/√Hz f = 10 kHz 16 nV/√Hz INPUT CURRENT NOISE f = 1 kHz 0.01 pA/√Hz Rev. 0 | Page 3 of 12 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
