Datasheet AD712-EP (Analog Devices) - 4
DescriptionDual Precision, Low Cost, High Speed BiFET Op Amp
Pages / Page12 / 4 — Parameter Min. Typ. Max. Unit
File Format / SizePDF / 206 Kb
Parameter Min Typ Max Unit
AD712-EP
OPEN-LOOP GAIN 150 V/mV TMIN to TMAX 100 V/mV OUTPUT CHARACTERISTICS Output Voltage Swing High 13.9 13.0 V TMIN to TMAX 12.0 V Output Voltage Swing Low −12.5 −13.1 V TMIN to TMAX −12.0 V Current 25 mA POWER SUPPLY Rated Performance ±15 V Operating Range ±4.5 ±18 V Quiescent Current 5.0 6.8 mA 1 Input offset voltage specifications are guaranteed after 5 minutes of operation at TA = 25°C. 2 Bias current specifications are guaranteed maximum at either input after 5 minutes of operation at TA = 25°C. For higher temperatures, the current doubles every 10°C. 3 Defined as voltage between inputs, such that neither exceeds ±10 V from ground. 4 Typically exceeding −14.1 V negative common-mode voltage on either input results in an output phase reversal. Rev. 0 | Page 4 of 12 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
