Datasheet MAX4051/A, MAX4052/A, MAX4053/A (Maxim) - 3
Manufacturer | Maxim |
Description | Low-Voltage, CMOS Analog Multiplexers/Switches |
Pages / Page | 19 / 3 — Low-Voltage, CMOS Analog. Multiplexers/Switches. MAX4051/A, MAX4052/A, … |
Revision | 2 |
File Format / Size | PDF / 377 Kb |
Low-Voltage, CMOS Analog. Multiplexers/Switches. MAX4051/A, MAX4052/A, MAX4053/A
Low-Voltage, CMOS Analog Multiplexers/Switches MAX4051/A, MAX4052/A, MAX4053/A ELECTRICAL CHARACTERISTICS—Dual Supplies (continued)
(V+ = +4.5V to +5.5V, V- = -4.5V to -5.5V, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
MIN TYP MAX PARAMETER SYMBOL CONDITIONS UNITS (Note 2)
TA = +25°C -0.1 0.002 0.1 MAX4051A C, E -5 5 M -100 100 TA = +25°C -1 0.002 1 MAX4051 C, E -10 10 V+ = 5.5V, V- = -5.5V, M -100 100 VNO = 4.5V, TA = +25°C -0.1 0.002 0.1 VCOM = -4.5V MAX4052A, C, E -2.5 2.5 MAX4053A M -100 100 TA = +25°C -1 0.002 1 MAX4052, C, E -5 5 MAX4053 COM Off-Leakage M -50 50 ICOM(OFF) nA Current (Note 5) TA = +25°C -0.1 0.002 0.1 MAX4051A C, E -5 5 M -100 100 TA = +25°C -1 0.002 1 MAX4051 C, E -10 10 V+ = 5.5V, V- = -5.5V, M -100 100 VNO = -4.5V, TA = +25°C -0.1 0.002 0.1 VCOM = 4.5V MAX4052A, C, E -2.5 2.5 MAX4053A M -50 50 TA = +25°C -1 0.002 1 MAX4052, C, E -5 5 MAX4053 M -50 50 TA = +25°C -0.1 0.002 0.1 MAX4051A C, E -5 5 M -100 100 TA = +25°C -1 0.002 1 MAX4051 C, E -10 10 COM On-Leakage V+ = 5.5V, V- = -5.5V, M -100 100 ICOM(ON) nA Current (Note 5) VCOM = VNO = ±4.5V TA = +25°C -0.1 0.002 0.1 MAX4052A, C, E -2.5 2.5 MAX4053A M -50 50 TA = +25°C -1 0.002 1 MAX4052, C, E -5 5 MAX4053 M -50 50
_______________________________________________________________________________________ 3
