Datasheet KSZ8893MQL, KSZ8893MBL (Microchip)
ManufacturerMicrochip
DescriptionIntegrated 3-Port 10/100 Managed Switch with PHYs
Pages / Page116 / 1 — KSZ8893MQL/MBL. Integrated 3-Port 10/100 Managed. Switch with PHYs. Rev. …
File Format / SizePDF / 714 Kb
KSZ8893MQL/MBL. Integrated 3-Port 10/100 Managed. Switch with PHYs. Rev. 1.6. with patented mixed-signal low-power technology,
Datasheet KSZ8893MQL, KSZ8893MBL Microchip
KSZ8893MQL/MBL
Switch with PHYs
Rev. 1.6
three media access control (MAC) units, a highspeed non-blocking switch fabric, a dedicated
address lookup engine, and an on-chip frame buffer
memory.
Both PHY units support 10BASE-T and 100BASETX. In addition, one PHY unit supports 100BASE-FX.
The KSZ8893MQL/MBL comes in a lead-free
package, and is also available in industrial
temperature-grade
KS8893MQLI/MBLI
and
Automotive-grade KSZ8893 MQL AM. (See Ordering
Information). General Description
The KSZ8893MQL/MBL, a highly integrated layer 2
managed switch, is designed for low port count,
cost-sensitive 10/100 Mbps switch systems. It offers
an extensive feature set that includes rate limiting,
tag/port-based VLAN, QoS priority, management,
management information base (MIB) counters,
RMII/MII/SNI, and CPU control/data interfaces to
effectively address both current and emerging Fast
Ethernet applications.
The KSZ8893MQL/MBL contains two 10/100
transceivers ___________________________________________________________________________________________________ Functional Diagram HP AUTO
MDIX 10/100
T/TX/FX
PHY 1 10/100
MAC 1 10/100
T/TX
PHY 2 10/100
MAC 2 RMII/MII/
SNI 10/100
MAC 3 SNI
SPI SPI MIIM CONTROL
REGISTERS SMI FIFO, FLOW CONTROL, VLAN TAGGING, PRIORITY HP AUTO
MDIX 1K LOOK-UP
ENGINE QUEUE
MANAGEMENT BUFFER
MANAGEMENT FRAME
BUFFERS MIB
COUNTERS EEPROM
INTERFACE I2C
P1 LED[3:0]
P2 LED[3:0] LED
DRIVERS STRAP IN
CONFIGURATION LinkMD is a registered trademark of Micrel, Inc.
Product names used in this datasheet are for identification purposes only and may be trademarks of their respective companies. February 2010 1 M9999-021110-1.6
