Datasheet KSZ8893MQL, KSZ8893MBL (Microchip) - 8
ManufacturerMicrochip
DescriptionIntegrated 3-Port 10/100 Managed Switch with PHYs
Pages / Page116 / 8 — Micrel, Inc. KSZ8893MQL/MBL List of Figures. Figure 1. Typical Straight …
File Format / SizePDF / 714 Kb
Micrel, Inc. KSZ8893MQL/MBL List of Figures. Figure 1. Typical Straight Cable Connection. 31
Micrel, Inc KSZ8893MQL/MBL List of Figures Figure 1 Typical Straight Cable Connection 31
Figure 2. Typical Crossover Cable Connection . 32
Figure 3. Auto-Negotiation and Parallel Operation . 33
Figure 4. Destination Address Lookup Flow Chart, Stage 1 . 36
Figure 5. Destination Address Resolution Flow Chart, Stage 2. 37
Figure 6. 802.1p Priority Field Format. 48
Figure 7. KSZ8893MQL/MBL EEPROM Configuration Timing Diagram. 50
Figure 8. SPI Write Data Cycle. 52
Figure 9. SPI Read Data Cycle. 53
Figure 10. SPI Multiple Write . 53
Figure 11. SPI Multiple Read. 53
Figure 12: Far-End Loopback Path . 54
Figure 13. Near-end (Remote) Loopback Path . 55
Figure 14. EEPROM Interface Input Timing Diagram. 102
Figure 15. EEPROM Interface Output Timing Diagram. 102
Figure 16. SNI Input Timing Diagram . 103
Figure 17. SNI Output Timing Diagram . 103
Figure 18. MAC Mode MII Timing – Data Received from MII. 104
Figure 19. MAC Mode MII Timing – Data Transmitted to MII . 104
Figure 20. PHY Mode MII Timing – Data Received from MII . 105
Figure 21. PHY Mode MII Timing – Data Transmitted to MII . 105
Figure 22: RMII Timing – Data Received from RMII. 106
Figure 23: RMII Timing – Data Input to RMII . 106
Figure 24. I2C Input Timing. 107
Figure 25. I2C Start Bit Timing . 107
Figure 26. I2C Stop Bit Timing. 107
Figure 27. I2C Input Timing. 107
Figure 28. SPI Input Timing . 108
Figure 29. SPI Output Timing . 109
Figure 30: Auto-Negotiation Timing. 110
Figure 31. Reset Timing . 111
Figure 32. Recommended Reset Circuit . 112
Figure 33. Recommended Reset Circuit for interfacing with CPU/FPGA Reset Output. 112
Figure 34. 128-Pin PQFP Package. 114
Figure 35. 100_Ball LFBGA Package . 115 February 2010 8 M9999-021110-1.6
