Datasheet LT6376 (Analog Devices) - 9
Description | ±230V Common Mode Voltage G = 10 Difference Amplifier |
Pages / Page | 30 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless … |
File Format / Size | PDF / 2.1 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless otherwise noted. Gain Nonlinearity
LT6376
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless otherwise noted. Gain Nonlinearity Gain Nonlinearity Gain Error vs Temperature
100 10 100 10 VS = ±15V V V 80 S = ±15V S = ±15V G = 10 R 80 8 L= 100kΩ 8 RL= 1MΩ VOUT = ±10V 60 6 10 UNITS 60 6 DIV = 3.1 40 4 40 4 GAIN ERROR (m%) 20 2 20 2 0 0 0 0 –20 ERROR (ppm) –2 –20 –2 ERROR (ppm) –40 –4 GAIN ERROR (ppm) –40 –4 –60 –6 –60 –6 –80 –8 –80 –8 –100 –10 –100 –10 –15 –10 –5 0 5 10 15 –15 –10 –5 0 5 10 15 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) TEMPERATURE (°C) 6376 G19 6376 G20 6376 G21
Maximum Power Dissipation vs CMRR vs Temperature Output Voltage vs Load Current Temperature
50 20 5 Vs = ±15V 40 20 UNITS DIV = 3.1 15 DF14(12) θJA = 43°C/W 30 4 10 20 ATION (W) 10 5 V/V) 3 TAGE (V) 130°C 0 0 85°C 25°C –10 CMRR (µ –5 –45°C 2 –20 OUTPUT VOL –10 –30 1 –40 –15 MAXIMUM POWER DISSIP MS16(12) θJA = 130°C/W –50 –20 0 –75 –50 –25 0 25 50 75 100 125 150 175 0 5 10 15 20 25 30 –60 –40 –20 0 20 40 60 80 100 120 140 160 TEMPERATURE (°C) OUTPUT CURRENT (mA) AMBIENT TEMPERATURE (°C) 6376 G22 6376 G23 6376 G24
Frequency Response vs Input Referred Noise Density vs Gain vs Frequency Capacitive Load Frequency
40 40 500 DIV = 3.1 30 30 450 20 20 400 10 /√Hz) 10 350 0 Y (nV –10 0 300 DIV = 10.3 –20 –10 250 GAIN (dB) –30 DIV = 3.1 GAIN (dB) –20 0nF 200 DIV = 4.3 –40 0.5nF DIV = 5.1 –30 150 –50 1nF DIV = 3.1 DIV = 6.3 1.5nF –40 TAGE NOISE DENSIT 100 –60 DIV = 7.1 2nF VOL DIV = 8.3 –70 –50 3nF 50 DIV = 10.3 5nF –80 –60 0 0.001 0.01 0.1 1 10 0.001 0.01 0.1 1 10 1 10 100 1k 10k 100k FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (Hz) 6376 G25 6376 G26 6376 G27 6376f For more information www.linear.com/LT6376 9 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION E LECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
