Datasheet A2003, A2004, A2023, A2024 (Allegro) - 7
ManufacturerAllegro
DescriptionHigh Voltage High Current Darlington Arrays (Discontinued Product)
Pages / Page11 / 7 — 2003 THRU 2024 HIGH-VOLTAGE, HIGH-CURRENT DARLINGTON ARRAYS. ALLOWABLE …
File Format / SizePDF / 324 Kb
2003 THRU 2024 HIGH-VOLTAGE, HIGH-CURRENT DARLINGTON ARRAYS. ALLOWABLE COLLECTOR CURRENT. TYPICAL APPLICATIONS
2003 THRU 2024 HIGH-VOLTAGE, HIGH-CURRENT DARLINGTON ARRAYS ALLOWABLE COLLECTOR CURRENT TYPICAL APPLICATIONS
2003 THRU 2024 HIGH-VOLTAGE, HIGH-CURRENT DARLINGTON ARRAYS ALLOWABLE COLLECTOR CURRENT TYPICAL APPLICATIONS AS A FUNCTION OF DUTY CYCLE (Dual In-line-Packaged Devices, Suffix ‘A’) +VSS +V
600
1 16 2 15
1
3 14
2 400
4 13
3 4
5 12
5 6
6 11
7 200
7 10
NUMBER OF OUTPUTS CONDUCTING
PMOS
SIMULTANEOUSLY
OUTPUT 8 9
TA = +70°C
OUTPUT CURRENT IN mA/CHANNEL
RθJA = 60°C/W Dwg. No. A-9652 0 0 20 40 60 80 100
+V +V DD DUTY CYCLE IN PER CENT
Dwg. GP-070
1 16 2 15 (Small-Outline-Packaged Devices, Suffix ‘L’)
600
3 14 4 13
TA = +70°C RθJA = 90°C/W
5 12
400
6 11 200
7 10 2N4901
2
200
Ω 3
8 9
4 200 5 6 7
CMOS OUTPUT OUTPUT CURRENT IN mA/CHANNEL
NUMBER OF OUTPUTS CONDUCTING Dwg. No. A-9654A SIMULTANEOUSLY 0 0 20 40 60 80 100
Dwg. GP-044A
SATURATION VOLTAGE COLLECTOR CURRENT AS A AS A FUNCTION OF COLLECTOR CURRENT FUNCTION OF INPUT CURRENT
600 600 400 400 E G L A A LT IC O P Y V T N IO T URRENT TYPICAL A R U T PUT C IN 200 A 'D . S 200 X EQ A M AX. R M
COLLECTOR CURRENT IN mA COLLECTOR CURRENT IN mA
0 0 0 0.5 1.0 1.5 2.0 0 200 400 600
COLLECTOR-EMITTER SATURATION VOLTAGE INPUT CURRENT IN
µ
A
Dwg. GP-067 Dwg. GP-068 115 Northeast Cutoff, Box 15036 Worcester, Massachusetts 01615-0036 (508) 853-5000
