Datasheet AD5748 (Analog Devices) - 9
DescriptionIndustrial Current/Voltage Output Driver with Programmable Ranges
Pages / Page32 / 9 — Data Sheet. AD5748. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. …
File Format / SizePDF / 760 Kb
Data Sheet. AD5748. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. ESD CAUTION
Data Sheet AD5748 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 9
TA = 25°C unless otherwise noted. Transient currents of up to 100 mA do not cause SCR latch-up.
Table 4.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress AVDD to GND −0.3 V to +30 V rating only; functional operation of the device at these or any AVSS to GND +0.3 V to −28 V other conditions above those indicated in the operational AVDD to AVSS −0.3 V to +58 V section of this specification is not implied. Exposure to absolute DVCC to GND −0.3 V to +7 V maximum rating conditions for extended periods may affect VSENSE+ to GND AVSS to AVDD device reliability. VSENSE− to GND ±5.0 V
ESD CAUTION
Digital Inputs to GND −0.3 V to DVCC + 0.3 V or 7 V (whichever is less) Digital Outputs to GND −0.3 V to DVCC + 0.3 V or 7 V (whichever is less) VREF to GND −0.3 V to +7 V VIN to GND −0.3 V to +7 V VOUT, IOUT to GND AVSS to AVDD Operating Temperature Range, −40°C to +105°C Industrial Storage Temperature Range −65°C to +150°C Junction Temperature (TJ max) 125°C 32-Lead LFCSP Package θJA Thermal Impedance1 42°C/W Lead Temperature JEDEC industry standard Soldering J-STD-020 ESD (Human Body Model) 3 kV 1 Simulated data based on a JEDE 2S2P board with thermal vias. Rev. B | Page 9 of 32 Document Outline Features Applications General Description Table of Contents Revision History Functional Block Diagram Specifications Timing Characteristics Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Voltage Output Current Output Terminology Theory of Operation Software Mode Current Output Architecture Driving Inductive Loads Voltage Output Amplifier Driving Large Capacitive Loads Power-On State of the AD5748 Default Registers at Power-On Reset Function OUTEN Software Control Input Shift Register Readback Operation Hardware Control Transfer Function Detailed Description of Features Output Fault Alert—Software Mode Output Fault Alert—Hardware Mode Voltage Output Short-Circuit Protection Asynchronous Clear (CLEAR) Current Setting Resistor Packet Error Checking Applications Information Transient Voltage Protection Thermal Considerations Layout Guidelines Galvanically Isolated Interface Microprocessor Interfacing Outline Dimensions Ordering Guide
