Datasheet ADL5390 (Analog Devices) - 7
Description | RF/IF Vector Multiplier |
Pages / Page | 23 / 7 — Data Sheet. ADL5390. TYPICAL PERFORMANCE CHARACTERISTICS. FRF = 70MHz. … |
Revision | A |
File Format / Size | PDF / 653 Kb |
Data Sheet. ADL5390. TYPICAL PERFORMANCE CHARACTERISTICS. FRF = 70MHz. FRF = 140MHz FRF = 380MHz. –10. RF = 900MHz. GAIN (dB)
Data Sheet ADL5390 TYPICAL PERFORMANCE CHARACTERISTICS 10 5 4 5 3 0 2 +3
σ
–5 FRF = 70MHz 1 FRF = 140MHz FRF = 380MHz –10 F 0 RF = 900MHz F GAIN (dB) RF = 2400MHz –1 –15 –3
σ
–2 –20 CHANNEL GAIN MATCH (dB) –3 –25 –4 –30
04954-003
–5
04954-006
0 0.25 0.50 0.75 1.00 0 300 600 900 1200 1500 1800 2100 2400 GAIN SETPOINT FREQUENCY (MHz)
Figure 3. Gain Magnitude vs. Gain Setpoint, RF Frequency = 70 MHz, Figure 6. Channel Gain Matching (I to Q) vs. RF Frequency, 140 MHz, 380 MHz, 900 MHz, 2400 MHz (Channel I or Channel Q) Gain Setpoint = 1.0
10 9 TEMP = –40°C TEMP = +25°C TEMP = –40°C 5 8 TEMP = +85°C 7 TEMP = +25°C 0 6 –5 5 –10 4 GAIN (dB) GAIN (dB) –15 TEMP = +85°C 3 –20 2 –25 1 –30
04954-004
0
04954-007
0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 0 300 600 900 1200 1500 1800 2100 2400 GAIN SETPOINT FREQUENCY (MHz)
Figure 4. Gain Magnitude vs. Gain Setpoint, Temp = +85°C, +25°C, −40°C, Figure 7. Channel Gain vs. RF Frequency, Temp = +85°C, +25°C, −40°C, RF Frequency = 380 MHz (Channel I or Channel Q) Gain Setpoint = 1.0
4 5 +3
σ
= DASH LINE +3
σ
= DASH LINE 3 –3
σ
= SOLID LINE FRF = 70MHz –3
σ
= SOLID LINE FRF = 140MHz F 0 2 RF = 380MHz FRF = 900MHz FRF = 2400MHz 1 –5 0 –1 –10 GAIN ERROR (dB) FRF = 70MHz F –2 RF = 140MHz PHASE ERROR (Degrees) FRF = 380MHz –15 FRF = 900MHz –3 FRF = 2400MHz –4
04954-005
–20
04954-008
0 0.25 0.50 0.75 1.0 0 0.25 0.50 0.75 1.0 GAIN SETPOINT GAIN SETPOINT
Figure 5. Gain Conformance Error vs. Gain Setpoint, RF Frequency = 70 MHz, Figure 8. Single-Channel Phase Deviation vs. Gain Setpoint, Normalized to 140 MHz, 380 MHz, 900 MHz, 2400 MHz Gain Setpoint = 1.0, RF Frequency = 70 MHz, 140 MHz, 380 MHz, 900 MHz, 2400 MHz Rev. A | Page 7 of 23 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics General Structure Theory of Operation Noise and Distortion Applications Information Using the ADL5390 RF Input and Matching RF Output and Matching Driving the I-Q Baseband Gain Controls Interfacing to High Speed DACs Generalized Modulator Vector Modulator Vector Modulator Example—CDMA2000 Quadrature Modulator RF Multiplexer Evaluation Board Outline Dimensions Ordering Guide
