Datasheet AD8341 (Analog Devices) - 4
Description1.5 GHz to 2.4 GHz RF Vector Modulator
Pages / Page20 / 4 — AD8341. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameters. Rating. …
File Format / SizePDF / 625 Kb
AD8341. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameters. Rating. ESD CAUTION
AD8341 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameters Rating ESD CAUTION
AD8341 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameters Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage VPRF, VPS2 5.5 V stress rating only; functional operation of the product at these DSOP 5.5 V or any other conditions above those indicated in the operational IBBP, IBBM, QBBP, QBBM 2.5 V section of this specification is not implied. Operation beyond RFOP, RFOM 5.5 V the maximum operating conditions for extended periods may RF Input Power at Maximum Gain 13 dBm, referenced affect product reliability. to 50 Ω
ESD CAUTION
(RFIP or RFIM, Single-Ended Drive) Equivalent Voltage 2.8 V p-p Internal Power Dissipation 825 mW θJA (With Pad Soldered to Board) 59 °C/W Maximum Junction Temperature 125°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature Range (Soldering 60 sec) 300°C Rev. B | Page 4 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RF QUADRATURE GENERATOR I-Q ATTENUATORS AND BASEBAND AMPLIFIERS OUTPUT AMPLIFIER NOISE AND DISTORTION GAIN AND PHASE ACCURACY RF FREQUENCY RANGE APPLICATIONS INFORMATION USING THE AD8341 RF INPUT AND MATCHING RF OUTPUT AND MATCHING DRIVING THE I-Q BASEBAND CONTROLS INTERFACING TO HIGH SPEED DACs CDMA2000 APPLICATION WCDMA APPLICATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
