Datasheet HMC936ALP6E (Analog Devices) - 5
DescriptionGaAS MMIC 6 Bit Digital Phase Shifters, 1.2 - 1.4 GHz
Pages / Page6 / 5 — HMC936ALP6E. GaAs MMIC 6 BIT DIGITAL. PHASE SHIFTERS, 1.2 - 1.4 GHz. …
File Format / SizePDF / 446 Kb
HMC936ALP6E. GaAs MMIC 6 BIT DIGITAL. PHASE SHIFTERS, 1.2 - 1.4 GHz. Outline Drawing. Package Information. Pin Descriptions
HMC936ALP6E GaAs MMIC 6 BIT DIGITAL PHASE SHIFTERS, 1.2 - 1.4 GHz Outline Drawing Package Information Pin Descriptions
HMC936ALP6E
v03.0117
T M L - S ITA IG S - D R E T NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY IF 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. H 3. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.15mm PER SIDE. 4. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE. 5. ALL GROUND LEADS MUST BE SOLDERED TO PCB RF GROUND. E S 6. CLASSIFIED AS MOISTURE SENSITIVITY LEVEL (MSL) 1. S A
Package Information
H Part Number Package Body Material Lead Finish MSL Rating Package Marking [1] P HMC936ALP6E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL3 [2] H936 XXXX [2] Max peak reflow temperature of 260 °C [1] 4-Digit lot number XXXX
Pin Descriptions
Pin Number Function Description Interface Schematic 1 Vdd Voltage supply. These pins and exposed ground paddle 2, 20 GND must be connected to RF/DC ground. 3 RFIN This port is DC coupled and matched to 50 Ohms. The pins are not connected internally; however, all data 4 - 18, N/C shown herein was measured with these pins connected to 21, 25 RF/DC ground externally. 19 RFOUT This port is DC coupled and matched to 50 Ohms. 22 - 24, BIT6, BIT5, BIT4, Control Input. See truth table 26 - 28 BIT3, BIT2, BIT1 and control voltage tables. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
5
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Phase Error vs. State Insertion Loss vs. Temperature, Major States Only RMS Phase Error vs. Temperature Input P1dB, Major States Only Input IP2, Major States Only Input IP3, Major States Only Relative Phase Shift, RMS, Average, Max, All States Relative Phase Shift Major States Including All Bits Output Return Loss, Major States Only Phase Error, Major States Only Input Return Loss, Major States Only Normalized Loss, Major States Only Insertion Loss, Major States Only Absolute Maximum Ratings Bias Voltage & Current Control Voltage Truth Table Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials
