Datasheet HMC936ALP6E (Analog Devices) - 6
DescriptionGaAS MMIC 6 Bit Digital Phase Shifters, 1.2 - 1.4 GHz
Pages / Page6 / 6 — HMC936ALP6E. GaAs MMIC 6 BIT DIGITAL. PHASE SHIFTERS, 1.2 - 1.4 GHz. …
File Format / SizePDF / 446 Kb
HMC936ALP6E. GaAs MMIC 6 BIT DIGITAL. PHASE SHIFTERS, 1.2 - 1.4 GHz. Evaluation PCB
HMC936ALP6E GaAs MMIC 6 BIT DIGITAL PHASE SHIFTERS, 1.2 - 1.4 GHz Evaluation PCB
HMC936ALP6E
v03.0117
T M L - S ITA IG S - D R E T IF H E S S A H P
List of Materials for Evaluation PCB EV1HMC936ALP6 [1][3]
The circuit board used in the application should use Item Description RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA RF Connector have 50 ohm impedance while the package ground J3 Header 2mm, 16 Pin leads and exposed paddle should be connected C1, C2 1000 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. U1 HMC936ALP6E 6-Bit Digital Phase Shifter A sufficient number of via holes should be used to PCB [2] 117718 Evaluation PCB connect the top and bottom ground planes. The [1] Reference this number when ordering complete evaluation PCB evaluation board should be mounted to an appro- [2] Circuit Board Material: Rogers 4350 priate heat sink. The evaluation circuit board shown [3] Please refer to part’s pin description and functional diagram for pin out assignments on evaluation board. is available from Analog Devices upon request. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
6
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Phase Error vs. State Insertion Loss vs. Temperature, Major States Only RMS Phase Error vs. Temperature Input P1dB, Major States Only Input IP2, Major States Only Input IP3, Major States Only Relative Phase Shift, RMS, Average, Max, All States Relative Phase Shift Major States Including All Bits Output Return Loss, Major States Only Phase Error, Major States Only Input Return Loss, Major States Only Normalized Loss, Major States Only Insertion Loss, Major States Only Absolute Maximum Ratings Bias Voltage & Current Control Voltage Truth Table Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials
