Datasheet ADF5000 (Analog Devices) - 9
Description4 GHz TO 18 GHz Divide-by-2 Prescaler
Pages / Page12 / 9 — Data Sheet. ADF5000. OUTLINE DIMENSIONS. 3.10. 0.30. 3.00 SQ. 0.25. 2.90. …
RevisionA
File Format / SizePDF / 220 Kb
Data Sheet. ADF5000. OUTLINE DIMENSIONS. 3.10. 0.30. 3.00 SQ. 0.25. 2.90. PIN 1. 0.18. INDICATOR. 0.50. BSC. EXPOSED. 1.60. PAD. 1.50 SQ 1.40. 0.45
Data Sheet ADF5000 OUTLINE DIMENSIONS 3.10 0.30 3.00 SQ 0.25 2.90 PIN 1 0.18 INDICATOR 0.50 BSC EXPOSED 1.60 PAD 1.50 SQ 1.40 0.45
link to page 9
Data Sheet ADF5000 OUTLINE DIMENSIONS 3.10 0.30 3.00 SQ 0.25 2.90 PIN 1 0.18 PIN 1 INDICATOR 13 16 INDICATOR 0.50 12 1 BSC EXPOSED 1.60 PAD 1.50 SQ 1.40 9 4 8 5 0.45 0.20 MIN TOP VIEW BOTTOM VIEW 0.40 0.35 0.80 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO 0.75 0.05 MAX THE PIN CONFIGURATION AND 0.70 0.02 NOM FUNCTION DESCRIPTIONS SECTION OF THIS DATA SHEET. COPLANARITY SEATING 0.08 PLANE 0.20 REF -B 0 1 0 -2 6 -1 COMPLIANT TO JEDEC STANDARDS MO-220-WEED-6. 8 0
Figure 11. 16-Lead Lead Frame Chip Scale Package [LFCSP_WQ] 3 mm × 3 mm Body, Very Very Thin Quad (CP-16-18) Dimensions shown in millimeters
ORDERING GUIDE Temperature Package Branding Model1 Range Package Description Option
ADF5000BCPZ −40°C to +105°C 16-Lead Lead Frame Chip Scale Package [LFCSP_WQ] CP-16-18 Q1T ADF5000BCPZ-RL7 −40°C to +105°C 16-Lead Lead Frame Chip Scale Package [LFCSP_WQ], 7” Tape and Reel CP-16-18 Q1T EVAL-ADF5000EB2Z Evaluation Board 1 Z = RoHS Compliant Part. Rev. A | Page 9 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Evaluation Board PCB PCB Material Stack-Up Bill of Materials Application Circuit Outline Dimensions Ordering Guide
