Datasheet HMC794LP3E (Analog Devices) - 6
Description2 GHz Low Noise Programmable Divider (N = 1 to 4)
Pages / Page10 / 6 — HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Outline …
File Format / SizePDF / 788 Kb
HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Outline Drawing. Package Information
HMC794LP3E 2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Outline Drawing Package Information
HMC794LP3E
v01.0612
t M s s - r o t c e t e notes: 1. LeADFrAMe MAteriAL: coPPer ALLoy s & D 2. DiMensions Are in incHes [MiLLiMeters]. 3. LeAD sPAcinG toLerAnce is non-cuMuLAtive r 4. PAD Burr LenGtH sHALL Be 0.15mm MAXiMuM. e PAD Burr HeiGHt sHALL Be 0.05mm MAXiMuM. 5. PAcKAGe WArP sHALL not eXceeD 0.05mm. iD 6. ALL GrounD LeADs AnD GrounD PADDLe Must iv Be soLDereD to PcB rF GrounD. 7. reFer to Hittite APPLicAtion note For suGGesteD
Package Information
PcB LAnD PAttern. y D c Part number Package Body Material Lead Finish MsL rating Package Marking [1] n HMc794LP3e roHs-compliant Low stress injection Molded Plastic 100% matte sn MsL1 [2] 794 XXX e [1] 4-Digit lot number XXXX u [2] Max peak reflow temperature of 260 °c q e r F I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
6
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
