Datasheet HMC447LC3 (Analog Devices) - 3
DescriptionSMT SMT GaAs HBT MMIC DIVIDE-BY-4, 10-26 GHz
Pages / Page8 / 3 — HMC447LC3. SMT GaAs HBT MMIC. DIVIDE-BY-4, 10 - 26 GHz. Output Voltage …
File Format / SizePDF / 401 Kb
HMC447LC3. SMT GaAs HBT MMIC. DIVIDE-BY-4, 10 - 26 GHz. Output Voltage Waveform, Pin= 0 dBm, Fout= 2.5 GHz, T= 25 °C
HMC447LC3 SMT GaAs HBT MMIC DIVIDE-BY-4, 10 - 26 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 2.5 GHz, T= 25 °C
HMC447LC3
v04.0514
SMT GaAs HBT MMIC DIVIDE-BY-4, 10 - 26 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 2.5 GHz, T= 25 °C Absolute Maximum Ratings
100 RF Input (Vcc = +5V) +13 dBm T Supply Voltage (Vcc1, Vcc2) +5.5V M 60 Junction Temperature (Tj) 135 °C Continuous Pdiss (T = 85 °C) (mV) 20 595 mW (derate 11.9 mW/° C above 85 °C) S - S Thermal Resistance (R ) TH 84 °C/W -20 (junction to ground paddle) R AMPLITUDE Storage Temperature -65 to +150 °C O -60 Operating Temperature -40 to +85 °C T C ESD Sensitivity (HBM) Class 1A -100 E 22.7 22.9 23.1 23.3 23.5 23.7 T TIME (nS)
Typical Supply Current vs. Vcc
E Vcc1, Vcc2 (V) Icc (mA) ELECTROSTATIC SENSITIVE DEVICE 4.75 84 OBSERVE HANDLING PRECAUTIONS 5.0 96 5.25 108 S & D Note: Divider will operate over full voltage range shown above R E ID IV Y D C N E U Q E R F Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
