Datasheet HMC437MS8G, 437MS8GE (Analog Devices) - 3
DescriptionSMT 4 SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz
Pages / Page6 / 3 — HMC437MS8G / 437MS8GE. SMT GaAs HBT MMIC. DIVIDE-BY-3, DC - 7 GHz
File Format / SizePDF / 362 Kb
HMC437MS8G / 437MS8GE SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz
v05.1211
SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
4 300 200 4 100 t 0 t M -100 M s -200 s AMPLITUDE (mV) s - -300 -400 s - r -500 r o 22.5 23 23.5 24 24.5 25 25.5 o t TIME (ns) t c c e e t t e
Absolute Maximum Ratings Reliability Information
e rF input Power (vcc = +5v) 13 dBm Junction temperature to Maintain 135 °c 1 Million Hour MttF nominal +5v supply to GnD -0.3v to +5.5v s & D nominal Junction temperature Max Peak Flow temperature 260 °c 122 °c (t = 85 °c) s & D r storage temperature -65 to +150 °c thermal resistance 101.5 °c/W r e esD sensitivity (HBM) class 1A (Junction to GND Paddle, 5V Supply) e iD operating temperature -40 to +85 °c iD iv iv y D Dc blocking capacitors are required at rF input and rF output ports.
Typical Supply Current vs. Vcc
choose value for lowest frequency of operation. y D c vcc (v) icc (mA) c n 4.75 64 n e eLectrostAtic sensitive Device 5.0 69 e u oBserve HAnDLinG PrecAutions 5.25 75 u q note: Divider will operate over full voltage range shown above q e e r r F F Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
4 - 3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
