Datasheet HMC394LP4, 394LP4E (Analog Devices) - 7
DescriptionGaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz
Pages / Page10 / 7 — HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. …
File Format / SizePDF / 591 Kb
HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. Evaluation PCB. List of Materials for
HMC394LP4 / 394LP4E GaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz Evaluation PCB List of Materials for
HMC394LP4 / 394LP4E
v09.0114
4 4 t t M M s s s - s - r r o o t t c c e e t t e e s & D s & D r r e The circuit board used in the application should use RF circuit design techniques. Signal lines should have 50 e iD Ohm impedance while the package ground leads and backside ground slug should be connected directly to iD iv the ground plane similar to that shown. A sufficient number of via holes should be used to connect the top and iv bottom ground planes. The evaluation circuit board shown is available from Hittite upon request. y D y D c c n n e e u
List of Materials for HMC394LP4 Evaluation
u q
Evaluation PCB 104898 [1] PCB Truth Table
q e Item Description Function S1 S2 S3 S4 S5 e r J1 - J3 PCB Mount SMA RF Connector Output Low 0 0 0 0 0 r F C1 - C2 [2] 1.0 µF Tantalum Capacitor / 2 1 0 0 0 0 F C3 - C4 [2] .01 µF Capacitor, 0603 Pkg. / 3 0 1 0 0 0 C5 - C8 1000 pF Capacitor, 0603 Pkg. / 4 1 1 0 0 0 R1* Resistor SIP 10 K ohm - - - - - - S1 - S6 Jumper (shunt) 2mm / 32 1 1 1 1 1 Note: 0 = Jumper Installed. U1 HMC394LP4 / HMC394LP4E 5-Bit Counter 1 = Jumper Not Installed. PCB 104435 Eval Board Note: The evaluation PCB for the HMC394LP4 contains [1] Reference this number when ordering complete evaluation PCB 10K Ohm pull up resistors for each of the five control inputs A0 through A4. Programming the 31 distinct division ratios [2] Optional components. consists of installing or removing jumpers S1 through S5, as shown above. Jumper S6 must always be installed to provide ground to pin 20. Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
4 - 7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
