Datasheet HMC363G8 (Analog Devices)
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-8, DC - 12 GHz
Pages / Page6 / 1 — HMC363G8. SMT GaAs HBT MMIC. DIVIDE-BY-8, DC - 12 GHz. Typical …
File Format / SizePDF / 327 Kb
HMC363G8. SMT GaAs HBT MMIC. DIVIDE-BY-8, DC - 12 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC363G8 Analog Devices
HMC363G8
v00.0203
6
Typical Applications Features
Prescaler for DC to X Band PLL Applications: T Ultra Low SSB Phase Noise: -153 dBc/Hz • Point-to-Point / Multi-Point Radios Wide Bandwidth • VSAT Radios Output Power: 4 dBm • Test Equipment Single DC Supply: +5V S - SM R • Fiber Optic 8 Lead Hermetic SMT Package O • Military & Space T C E T
E The HMC363G8 is a low noise Divide-by-8 Static Divider with InGaP GaAs HBT technology in an 8 & D lead glass/metal (hermetic) surface mount package. S This device operates from DC (with a square wave R input) to 12 GHz input frequency with a single +5V E DC supply. The low additive SSB phase noise of -153 ID dBc/Hz at 100 kHz offset helps the user maintain good IV system noise performance. Y D NC E U Q E R F
Electrical Specifi cations, T = +25° C, 50 Ohm System, Vcc = 5V A
Parameter Conditions Min. Typ. Max. Units Maximum Input Frequency 12 13 GHz Minimum Input Frequency Sine Wave Input. [1] 0.2 0.5 GHz Input Power Range Fin = 1 to 6 GHz -15 >-20 +10 dBm Fin = 6 to 8 GHz -15 >-20 +5 dBm Fin = 8 to 12 GHz -10 >-15 0 dBm Output Power Fin = 12 GHz 1 4.0 dBm Reverse Leakage Both RF Outputs Terminated 55 dB SSB Phase Noise (100 kHz offset) Pin = 0 dBm, Fin = 6 GHz -153 dBc/Hz Output Transition Time Pin = 0 dBm, Fout = 882 MHz 100 ps Supply Current (Icc) 90 mA 1. Divider will operate down to DC for square-wave input signal. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
6 - 14
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
